windows down peaked 28hz, windows up peaked 39hzthe sub doesn't change the vehicles res frequency.show me some picks. if you do it how j tell you too you will find the true res frequency. typically that alignment sealed up will peak around 48-50..
how many times do you have to be told that metering 10 years ago isnt the same as metering nowover 10 years ago I was doing 153-154 with ONE 9515 on about 2k at 48. for surely you don't think I'm impressed with 4 15 and 30k barley breaking 160 do you? and remember this was over q0 years ago
garb a 1.5 cubed sealed box and a sealed box woofer.sa z4 is perdectwindows down peaked 28hz, windows up peaked 39hz
of course it doesn't change the vehicle res frequency, but you wont be able to guess that, better off guessing what the overall peaks are tbh
that was on music.. just because it's not screw doesn't mean it's not music. it was rep your city by Lil john. it metered the same as tones..Yea metering isn't the same and 48hz? Gross that's what I'm talking about. People don't do the numbers we are doing at the freq we doing then at... At world finals the judge **** his pants that the Hhr was peaking at 35hz when the other guys are all 50hz lmao... Then we go outside an demo for 2 hours while everyone else looks at their 40-50hz burp machines
If your using a zv4 3cubes after displacement port 10"x3.5" tuned to 28hz woofer and port on same baffle.Lol can someone attempt to answer my question ? And also what specs should I do for the new enclosure build ?
He has to be real music... No altered music is allowed for bass boxing.that was on music.. just because it's not screw doesn't mean it's not music. it was rep your city by Lil john. it metered the same as tones..
No, lol. I am selling my zv4 and the box I have for it. I asked if someone can tell me how much I should start it at so I have an idea. I also said I am getting two HDS312's and wanted to know the specs for an enclosure for a new box fitting two of those.If your using a zv4 3cubes after displacement port 10"x3.5" tuned to 28hz woofer and port on same baffle.
How much you pay. those subs actually will do good in a slightly larger box. 5 cubes tuned to 36 will *******. it really depends on what type of frequency response you want. 4.5 is gonna peak hard between about 32 and 60. in most cabins. trunk cars and larger cabin peak lower with trucks and walls peak higher. typically around 50-55 with no mods for trucks and large cars 42-44. just depends on how we there built etc..No, lol. I am selling my zv4 and the box I have for it. I asked if someone can tell me how much I should start it at so I have an idea. I also said I am getting two HDS312's and wanted to know the specs for an enclosure for a new box fitting two of those.
I paid $599 for the sub $230 for the box. And okay well i have a fairly big trunk for a sedan. If I am told the best possible specs, that will make the subs perform at full potential I would appreciate it. I just measured my trunk, I have 40" wall to wall, 17" clearance, and about 35" depth because of where my amp is mounted.How much you pay. those subs actually will do good in a slightly larger box. 5 cubes tuned to 36 will *******. it really depends on what type of frequency response you want. 4.5 is gonna peak hard between about 32 and 60. in most cabins. trunk cars and larger cabin peak lower with trucks and walls peak higher. typically around 50-55 with no mods for trucks and large cars 42-44. just depends on how we there built etc..
