Have a AQ2200, no sub..
the Z4 is inefficent abit because of the high MMS but ti should still jam with 2kw. if you have the 12 id do about 2.25 tuned to 36 for daily. you dont need to tune that low with that large of a box. even tuned to 36 the F3 is going to be close to 28hz still plenty low.. that being said you can probably find a woofer that works better off that power. like the SSA xcon or ascent audio havoc and sundown z3
So your giving advice on a zv4 and you have never seen one of real life or used one... Get the fvck outta bro
I've used so many ******* woofers in my day it's not funny.
plus I've built a few so I know how the subs responds. as long as the parameters are accurate.
you idoits don't understand that the parameters tell you about every measurable aspect of the driver. not to mention sundown had a dumax on it so yes I can.
surely not 3 cubes. my God that thing is going to be bottom heavy
I've used so many ******* woofers in my day it's not funny.plus I've built a few so I know how the subs responds. as long as the parameters are accurate.
What your not understanding is what works on paper doesn't work in real life every time. Every build is different and ever car cabin is different. And yes a zv4 is a bottom heavy woofer if you want your bass 15hz-40hz. 3cubes tuned to 28hz with a port 10"x3.5" for a 12" zv4 is golden
just like that SP15 was in 4.25 tuned low did the same thing.
except this woofer has a 3" coil.
starting to wonder if yall have any ******* clue.
sundown specifically recommends small ported boxes. not 1 cube over the typical alignment.
I assure you I understand cabin gain an losses.
I'm so seasoned I bet I can guess your cabins res frequency.. not Nessicarlly where it peaks it's true resonance frequency.
give me the dimensions and what you have done to reinforce it..
I assure you I understand cabin gain an losses.I'm so seasoned I bet I can guess your cabins res frequency.. not Nessicarlly where it peaks it's true resonance frequency.
whats my cabin res frequency windows down, windows up. re mt 15 in a 5 cube net box at 35 hz (reconed by psi with daily spiders afaik), 8 x 18 inch octo port flared both ends. loads 4-5 inches off the pass ext cab door in a 00 silverado.
i'll give you a hint, big cabin gain down low
just like that SP15 was in 4.25 tuned low did the same thing.except this woofer has a 3" coil.
Results don't lie. Here in Michigan we got some of the nastiest builds with sundowns.
2 zv4 12s in 6 cubes tuned to 28hz does 151db sealed at 28hz... That is crazy for a trunk car
4 zv4 15s in 30cubes and did a 158db at 33hz... Now has nsv3 and doing 160db and in week he will have team 15s and hopefully gain another db
Both well oversized and the numbers don't lie. Most people doing 158db on music do it 40hz + and do it with 25,000watts.. He was doing it half that power. And people run their mouths until we show up at shows and shut everyone up
Results don't lie. Here in Michigan we got some of the nastiest builds with sundowns. 2 zv4 12s in 6 cubes tuned to 28hz does 151db sealed at 28hz... That is crazy for a trunk car
fuck me 30 cubes net? what the hell is this 7.5 cubes net per sub plus shared airspace equals possibly 8-9 cubes per woofer?
the sub doesn't change the vehicles res frequency.
show me some picks. if you do it how j tell you too you will find the true res frequency. typically that alignment sealed up will peak around 48-50..
delete
Delete
delete
Delete
Papermaker85
