Have a AQ2200, no sub..
yes get the D2 wire down to 1 ohm.
Okay thank you very much for your help. Just one more question. Do you have any other recommendations? Only because whatever I purchase I am going to keep for a long time because I hate this, its like buying a car. If you have anything else I can research please let me know. Thanks again!
this is a member on here that has the same sub in a similar box specs as you on half your power, not sure if this is satisfactory for you. You could also keep the same box and just add some 2x4s to take up some space to get to 2.5 cubic feet and your tuning will be around 34hz without having to cut down ports.
That is actually perfect. As of making the adjustments on the box, ill have to look into that. But as of any other recommendations, nothing else I can research ?
its simple. get (1) 2 ohm sub so you can wire it parallel and get a 1 ohm load. don't go DC audio, you will spend more time reconing than listening to music. don't go with sa either, they aren't bad but everyone has them. they are as common as kickers now. go with a hdc4 or aa mayhem
delete
Delete
delete
Delete
Papermaker85
