SlugButter
CarAudio.com VIP
1 of them on 750 watts is a banging little system. 4 of those on 3000 would be something I would want to try for sure.
You’ll need a solid 2500 for sure. The Orion looks decent
I put 2 in 1 cube at 35hz on 1400 rms, and they were quite impressive.
Aren’t you adding displacement for sub, bracing and port? Whose doing your math on this deal?You put two 8's in one cube? One cube each, right? How would you put 2-8's in 12"x12"x12"?
A 6 inch aero with flared ends would be what I would do, if it were my system, and I could fit it in. Ported to the passenger side, subs forward.
It was .5 cubes per sub, but after displacement for sub, port and bracing it was obviously bigger than .5 overall. It changes for the size of the port in sq, inches, and tuning. Bracing is differen. Some guys use a ton of wood that takes up slot of displacement. Some guys use all thread, which takes up much less. It could be 1 cube per sub after displacement I suppose, but this is a custom box. It should be a pretty specific number. An aero port totally changes the overall box size compared to a slot port at the same tuning.
