I Sold the Bug! 🥺, So, New Build
You’ll need a solid 2500 for sure. The Orion looks decent
I had one but sold it. Everybody told me that my Bug couldn't run it. It was over 2,980 on the birth sheet.
It was .5 cubes per sub, but after displacement for sub, port and bracing it was obviously bigger than .5 overall. It changes for the size of the port in sq, inches, and tuning. Bracing is differen. Some guys use a ton of wood that takes up slot of displacement. Some guys use all thread, which takes up much less. It could be 1 cube per sub after displacement I suppose, but this is a custom box. It should be a pretty specific number. An aero port totally changes the overall box size compared to a slot port at the same tuning.
When I talk about making the sq inches of port a little oversized, that also lengthens the port at the same port tuning, making the box a bit larger also, and sometimes causes issues even fitting the port into the box.
American Bass sucks as far as specs for their subs. If I remember correctly, the VFL wants between .75 and 1.0 cubic feet net. So, I was thinking of a 4 cube box before port and speaker displacement. I probably wouldn't do any bracing, but a 1" MDF top.
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
