Central Region Updated DFW build day
IA,IL,IN,KS,MI,MO,MN,NE,OH,OK,TX,WI
So Im excited for the build day. My front right door needs new deadening, ensolite, rewire, so I figured I would do that and my other 3 speakers along with new headunit install all in one day...
Ill have an MT and Brahma MKII to recone. We can wall the Brahma if you want before the recone //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Also will be doing some deadening of the B-pillar.
I would like to show up just for this.
Eric im going to text you...
I need to rerun my speaker wire, install 9887, redeaden the front right door, deaden the trunk. Rebuild my false floor. Rewire my amps and batterys and install a DLS A5, and see if i like comps + 1 sub over comps+coaxial+2subs.
I need help installing a viper5900+glass break...
Ineed you to rerun my speaker wire, install 9887, redeaden the front right door, deaden the trunk, rebuild my false floor, rewire my amps and batterys and install a DLS A5 all while I sit and crack jokes about underage teens and young mothers. Also when you get done I am sure I will change my mind before I give it a listen so you will need to then hook up my comps, coaxials, and two subs.
Also I need you to install a viper5900 and glass break while I hit on your sister.
16
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
bigbirney420
bigbirney420
Omaha, NE
nbudros
chillin
    Jun 14, 2024
