Central Region Updated DFW build day
IA,IL,IN,KS,MI,MO,MN,NE,OH,OK,TX,WI
Im gonna sneak in your room tonite //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
:edit: got your PM. The truck is at the tire place right now getting new tires mounted on the factory rims. I'll leave around 3-3:30. Puting me in Dallas between 6:30 and 7. want to go to dinner with me sn00kums?
Sounds good. Just call the cell.
Are you coming to dallas just for fun or do you have business to attend? How long you are intending on staying?
Justin, I have 10oz of glass and 2 gallons of resin just sitting here now since i went a different route with my floor. You want to redo your kicks? I also got plenty of Rage too, so sanding shouldn't be a problem //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Eric im going to text you...
Ineed you to rerun my speaker wire, install 9887, redeaden the front right door, deaden the trunk, rebuild my false floor, rewire my amps and batterys and install a DLS A5 all while I sit and crack jokes about underage teens and young mothers. Also when you get done I am sure I will change my mind before I give it a listen so you will need to then hook up my comps, coaxials, and two subs.
Also I need you to install a viper5900 and glass break while I hit on your sister.
The **** ever... I didnt change my mind this time... Some one jacked my ****ing deck, so i had to search for a new one on the forums, then came across this amp. So no.
But i am perfectly capable of doing everything my self, And I have the only time I need help is when i watch some one do it for the first time, almost every time after that I can handle everything my self. Ask moke, I pay attention and usualy get things down so the next time I can do it all.
The alarm is a whole new ball park.
cold=not good for FG... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
its not that cold //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif the high this weekend is actually around 72 hopefully it stays steady until next weekend. either way microwave some water and dip the resin tub in the water to warm it up and start mixing the activator and glass away(tip form joseph). or mix a hot a batch and break out the heatlamps. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
shouldnt be too hard. you could probably install the deck run the new speaker wire within an hour if you know your way around the car.
bigbirney420
bigbirney420
Omaha, NE
nbudros
