Best amp to power an FI “Q” 12??
What version of that Q sub
What box parameters
Upgraded electrical
This info will be important to get a good answer
My 12” FI SSD old ufo looking motor was run on 1500 Rockford Fosgate and that sub was rated either 750 or 1000
18”x21”x18”
Ported
FI “q” 12”
Dual 1 ohm(I think)
Upgrade electrical? None
It’s going behind the passenger seat of a 2018 Ford F-150 supercrew cab. The split rear seat will be folded up.
Which version ..? as in what options does it have... I had a Fi Q with full upgrades before and I ran a 2200w amp to it. 1000w was barely enough to tickle it. No matter what version you have, I would look into upgrading your amp and electricals. The more the better honestly. You can try it out with your jbl amp first and go from there.
I honestly don’t know which brands make high end amps anymore. Back in the day, hifonics, soundstream, Phoenix gold we’re top
That was back then. Now everything has gone china with those mainstream brands. They are not made like how they used to be.
Here’s a good place to start:
http://www.soundsolutionsaudio.com
Classified section in this forum for used gems
I would also ask bigblank69 as he dynos budget amps and he has no use for them afterwards.
Also ask Louisiana_crx as he is trying to get rid of his huge collection of antique amps lol
Is that a new sub or older model
Big 3 and 1/0 power and ground minimum
I would put the largest AGM Battery I could fit under the hood.
A new truck should have a fairly strong alternator from the factory
Big 3 should cost $50 if you spend wisely
This upgrade augments three key cables in the electrical system with 1/0 or 4 gauge wires: the battery ground to chassis wire, the chassis to engine block wire, and the alternator plus to battery plus wire
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
So I don't know what i'm doing but I really like the used H-KO but when i look at the specs it looks like it could overpower the sub if I'm...
19
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
968
859
Have an Xli 2500 as a sub amp in the music room, overkill for sure, never overheats, never skips a beat.
150
9K
jeeper2269
jeeper2269
Somewhere, OR
wew lad
