Any one have experience with hoppin up V8's.
Well K_Schutte has been helpin a lot so all of yall **** lol. jk
He showed me a great deal on Aluminum heads so im going to get some.
What heads are you gettin???
I had a 93 stang w/ 306, slightly worked TFS heads, custom HR cam, 10.5:1, Vic Jr intake, Pro-Systems carb, Probe pistons, KC clutch, Fidanza flywheel, Team Z suspension, 4.30 gears, and alot more crap I dont feel like listing.
My best time was an 11.39 in the 1/4. I shifted @ 6800.
add moar cylinders...
but in all seriousness, if u can do custom, bigger intake and exhaust
Taking care of that //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Would 4.30 gears kill you in the Quarter, seems like an 1/8th mile car.
They are Pro Comp Aluminum
http://cgi.ebay.com/ebaymotors/289-302-347-351w-5-0-Ford-Procomp-Aluminum-Heads-210cc_W0QQcmdZViewItemQQhashZitem2ea9b97682QQitemZ200415999618QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_1646wt_941
Can a C4 Handle 400 HP Stock ??
It can if you're tires dont hook. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Why not get an AOD and beef it up? My boy has one behind his T-76 turboed 347 stroker. The car can be seen here...
http://www.cprstreetmachines.com
Traction is where you start breakin things. I would rebuild that 8.8 too. I'm sure the clutches are prolly shot if it's been driven hard. Too bad you werent doing this 3 months ago. I parted my car out a few months back. It was everything I was running low 11s with too.
You could have used the pistons to build a 393 stroker, and ported the heads and intake to suit the needs of it.
Had to have steep gears due to the fairly large cam. I shifted at 6800rpms. I used a little taller tire to compensate for the gears. I was just hitting the rev-limiter when passing the line.
Pro-comps are not that good. I would sve up and do it right the first time. But you a used set of AFR's or TFS heads. Check this site out...
http://www.racingjunk.com
Im not racing though. If they are that good then i cant afford anything other than to stay stock.
They should be fine on a street car. I personaly know a guy who had the 215 CNC Pro-comps on his car and was running an 11.9. I helped him swap them out with some AFR 185s and he dropped his times to 11.5's. He was running a Redneck Performance C-4.
I found a set of AFR 165cc heads from a 302 on craigslist. How are these ?
Some of the BEST out of the box heads you can buy. Still not big enough for a 351. You cant have much work done to them either. They dont have a lot of metal left in them to port bc they are CNC'd.
Thats the first set of heads I had on my 93 when I was running mid-12s.
Johnny Law.Lulz
Banned
Johnny Law.Lulz
Virginia
k_schutte
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
