Budget build advice - Haven't built a system in 20 years
DSP - is it a must have?
  • Yes, it's a MUST
    Votes: 0 0.0%
  • No, it's unneeded at this budget/use
    Votes: 0 0.0%
  • It's nice to have but not neccessary
    Votes: 1 100.0%
  • Total voters
OK, so I'm a bit out of the loop, and spent the past few weeks reading up and refreshing my completely out of date knowledge. I'm trying to build a budget SQ build, and I'm trying to figure out just how important DSP is these days. 20 years ago, DSP was basically only used in HIGH end systems, and we got along without it just fine.
So, basically, if everyone says DSP is a must have, I'll be going with Kicker KEY amps (200.4, 500.1) that have DSP and Auto-EQ built in, or I'll be going with an Audiocontrol A1100.5, which is higher powered, more flexibility in terms of what ohms I can run at, but no DSP or EQ. The amp choice also determines the sub choice, as listed below.
Anyways, I built out a build list on Crutchfield using brands my local installer carries. Let me know if I should change anything or if my picks are completely wrong here:
Car - 2024 Nissan Ariya
Head unit - Stock
Front components - Infinity Reference REF607CF - I was looking for a warmer tone for the speakers, and I've heard Infinity fits the mold here.
Rear Coax (Are they even needed?) - Infinity Primus 603F
Subwoofer - Either a Rockford Fosgate P3D2-12 OR an AudioControl SPK-12S2, depending on the amp(s).
Amps - Kicker 47KEY200.4 and Kicker 47KEY500.1, or an AudioControl A1100.5
Total HARDWARE budget is, so far, under $1200, though I know install labor will tack on a significant sum to the final tally.
Anyways, I'm so open to suggestions, it's not even funny. I think I picked some decent brands, but I know some of the older high end stuff (Soundstream, Precision Power, etc) seem like they're low end garbage now.
Head unit - Stock
It sounds like you're putting a lot of thought into your system and doing your research, which is great! Let's break down your choices and address your questions about DSP and other components.
1. DSP Importance: Digital Signal Processing (DSP) has indeed become much more common and beneficial in car audio systems. Modern DSPs can help with time alignment, equalization, and optimization of sound based on the vehicle's acoustics. While you can still build a good sound system without it, having DSP allows for much finer control over sound quality, especially in a car environment where acoustics can be challenging. If your budget allows, going with the Kicker KEY amps with DSP could be a worthwhile investment, especially for the convenience of Auto-EQ.
2. Front Components: The Infinity Reference REF607CF is a solid choice. They’re known for their good sound quality, especially with a warmer tone, which aligns with your preference. This should provide a nice listening experience.
3. Rear Coaxials: Rear speakers can be a matter of personal preference. Some people like having rear fill for a more immersive soundstage, while others prefer the clarity of just front speakers. If you listen primarily to music and want the best sound quality, you might consider skipping the rears or investing in high-quality ones if you feel you need them.
4. Subwoofer Choices: The Rockford Fosgate P3D2-12 is a very well-regarded subwoofer and is known for its punchy bass. The AudioControl SPK-12S2 is also a solid choice, especially if you’re looking for an option that could pair well with the finer control of their amps. Your choice of sub should align with which amp you decide on.
5. Amplifier: If you prioritize having a DSP for tuning and optimization, the Kicker KEY amps are the way to go. If you lean towards more power and flexibility and feel comfortable tuning your system manually, the AudioControl A1100.5 is a great option and has the potential to deliver more power to your subwoofer, which can lead to better performance.
6. Budget: Your total hardware budget of under $1200 with the potential for installation labor is solid for the components you're considering. It’s important to keep in mind that investing in excellent installation will significantly impact the overall performance of your system.
### Recommendations:
  • Stick with the Kicker KEY amps if you want convenience, added features, and don't mind slightly less power. They should work well with the Infinity speakers and either sub.
  • Consider skipping the rear coaxials unless you have a specific use for them. Instead, you can allocate those funds towards a higher-quality front stage or sub.
  • Evaluate the sound tuning capabilities of your selected components. If possible, listen to some setups or demos at a local shop to hear the differences before making your final decision.
In summary, your picks are generally solid, and your consideration of DSP is very relevant in today's market. Ultimately, choose what suits your listening preferences best, keeping in mind that clarity and sound staging often come from a good front stage rather than rear fill. If you have any more specific questions about components or setups, feel free to ask!
Have you looked into how much 12v power that you have available? I know that some electric cars only have about 200w of power available at 12v due to limitations of the 12v power supply that is running off the high voltage ev battery.
It's a normal 12v battery, and I've seen systems with much higher wattage installed in other Ariyas. Should be ok, but thanks for brining that up. Would have been awful if it wouldn't support the wattage.
I would say that your selections are nice equipment, by and large, but unless you are bound to purchase from Crutchfield, better options exist.
Given the vehicle, I'd look for very efficient models.
Example:
Start with a simple DSP (that will take high-level OEM speaker leads) so you can make up the difference in cost by negating the need for speakers with crossovers.
This is out of stock everywhere because it's an excellent performer and the cost is very reasonable.
$155.00
Front 6.5" component Speakers: 2 or 4 ohm depending on the amp (see below)
$150.00 (2 ohm version):
Tweeters: $62.00 to $100.00
Good $62.00 pair:
Better $100 pair
- OR -
Best $100.00
Also best if you can actually find them in stock anywhere: $86.00
Rear fill. This is not necessary but nice if you like to have the ability to play for a full or partially occupied car. Since you will have the ability to EQ them with the DSP, I'd focus on full range and efficiency; a 2-way is not needed. Set the DSP response for 80 to 3k as the goal.
This will allow you to enjoy the rear fill without drawing the front stage too far back $43.00 shipped
To keep the budget aligned without compromising the sound quality or output, go with a prefab-loaded sub from CT Sounds.
Single 12 (W/first time buyer 11% discount) $196.00
And preferably if you have the room - dual 10" $285.00
And absolutely if you have the room and the budget: $339.00
Amplification.
This will largely depend on which subwoofer you select (as in duals or single). That said, this unit is by far the best value out there currently, and you can dictate the output using the gain controls on both the amp and the DSP. It's such a good deal, not going to bother with other options.
Since all the subs I've listed can be rewired to 4 ohms, this amp will output close to 2000 watts at 4 ohms, runs cooler at 4 ohms, has its highest efficiency and damping factor (woofer control) ability at 4 ohms, just a great way to get the most out of the setup and keep things running cool and effecient. Soundigital EVO 6 3000.1 (2-ohm version)
$170.00
Amplifier for the front 2-way components and the rear fill: 1 amp for all; using 2-ohm fronts gives you 200x2 for the front midbass and 100 x 4 at 4 ohms for the rear fill and the tweeters. $260.00
I don't see a lot of extras that will also be needed, such as deadening/installation materials and wiring; labor is a whole notha thing.
Sound treatments are a must and essential (even in a quiet EV):
Can't beat this. $40.00 for 36 sq ft - and they offer a first-time discount of 10% so get two!
1 for $36.00, two for $72.00
You can figure at least another $150.00 to $300.00 for wiring, cables, etc.
Head unit - Stock
To answer your question no, you don't need a DSP. Will you want one? Yes, you will want one if you're keeping the factory radio. An SQ build is a personal taste. It all depends on what you believe sounds good. Some people will be happy with a deck install, where others will need a $5000 system to be happy.
Factory radios come tuned to have a specific sound coming from the factory speakers. Change the speakers, and you change the sound. Sometimes it's good and sometimes it's bad. A DSP will allow you to tune each speaker to what you like. The equipment you chose, I believe you will be satisfied with them.
entropism
entropism
Scotch Plains, NJ
Old_Slapper
Mike2368Firebird
    Jun 17, 2026
Stylesinc2309
    Jun 16, 2026
