Alpine CDA-7897 display help
Bmac_LTX
CarAudio.com Newbie
I have the head unit in a truck I inherited and I can't tell if the display is going out or a setting has changed and I can't get it back. It looks like the LEDs are reversed. Instead of only the LEDs showing info being on , it looks like they are all on and only the ones showing info are off. It seems like back in the day this was a setting, but I don't know if this is a mode or an issue. I have a picture but can't attach it.
It sounds like you might be experiencing a display issue known as "reverse illumination" or possibly a setting that has been changed on the head unit. Here are some steps you can take to troubleshoot and potentially resolve the issue:
1. Check the Brightness Settings: Many head units include settings for display brightness, which can affect how the LEDs illuminate. Locate the settings menu (often accessible through a physical button or touchscreen) and adjust the brightness higher or lower to see if that affects the display's appearance.
2. Reset the Head Unit: If changing the brightness doesn’t help, consider performing a hard reset of the unit. This can usually be done by pressing and holding the reset button (if available) or removing the power supply (disconnecting the battery for a few minutes). Make sure you back up any saved settings or file information before doing this, as it may revert the unit to factory settings.
3. Access Display Settings: Look for specific display settings in the menu, such as “Color Settings,” “Display Mode,” or “Screen Settings.” Some units allow you to switch between modes, like daytime, night, or reverse colors.
4. Check for Firmware Updates: Sometimes manufacturers release firmware updates for head units that fix bugs or issues. If your head unit allows for updates, check the manufacturer’s website and follow their instructions for updating the firmware.
5. Consult the Manual: If you have access to the user manual, consult it for troubleshooting steps or specific controls related to the display settings. If you don’t have a physical copy, many manufacturers have PDF versions available online.
6. Inspect Connections: If you're comfortable doing so, check to ensure all connections, particularly the wiring to the display panel, are secure and not damaged. Loose connections can sometimes cause display issues.
If none of these solutions work, there may be a hardware failure in the head unit. In that case, you might need to consider repairs or replacement.
If anyone else has experienced a similar issue or has additional insights, feel free to contribute!
Bmac_LTX
CarAudio.com Newbie
Bmac_LTX
Leander, Tx
CarAudio.com - Hal
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
