Loaded enclosure options
EricF
CarAudio.com Recruit
Hey everyone,
I'm looking at a few different loaded enclosures for the trunk of my 3 series BMW. Long story short, the amp I was using for 2 12" Kicker CompR's in my other vehicle wasn't making the advertised power, so I had to upgrade amps. I'll be using this left over amp for my car. It's a DB drive WDX 1000.1, (1000 watts @ 1ohm, 500 watts @ 2ohm and 250 watts @ 4ohm rating). I'd imagine going for a 1-ohm subwoofer set up would maximize the output of this amp?
I'm going back and forth on these loaded enclosures. Given the option between an 8, 10 and a 12" set up in a trunk I've heard discussion that you should go for the biggest sub you can fit to maximize output.
Memphis mojo 8" in a ported enclosure (900 watts rms @ 1ohm)
Skar SVR 2 8" in a ported enclosure (800 watts rms @ 1 ohm)
Kicker L7T 10" in a ported enclosure (500 watts rms @ 2ohm)
Kicker CompR 12" in a ported enclosure (500 watts rms @ 2ohm)
I really like the Mojo set up due to its size and I'd imagine it must be on steroids for an 8" sub to have a power rating of 900 watts rms. As much as I want earth shattering bass I know I'll need to lower my expectations for any of these set ups. I will be sound proofing the trunk to minimize any rattles.
Looking forward to hearing some opinions!
Hey everyone,
Hey EricF,
You've got a solid set of options there for your BMW's trunk setup! You're correct that going for a 1-ohm subwoofer configuration would maximize the output from your DB Drive WDX 1000.1 amplifier. Your understanding of wanting to drive the amp at its peak performance is spot on.
### Subwoofer Size and Configuration
1. Size: Generally, larger subwoofers can produce deeper bass and handle more power. However, they also require more space and can have a different dynamic in terms of sound response. Smaller subs can provide quicker transient response and may perform better in smaller enclosures or tighter spaces.
2. Options Breakdown:
- Memphis Mojo 8" & Skar SVR 8": Both of these are impressive with high RMS ratings for their size. The Mojo, with 900 watts RMS at 1 ohm, suggests it could deliver some serious output despite its smaller size. This is great if you're looking for space efficiency and a powerful punch.
- Kicker L7T 10": This sub can handle 500 watts RMS at 2 ohms, which means it'll be slightly less powerful than the 8" options if you're running your amp at 1 ohm. The 10" size would give you a bit more low-end presence but at a reduced power handling compared to the 8" sub setups.
- Kicker CompR 12": Similar to the L7T, it also handles 500 watts RMS at 2 ohms. A 12" sub typically provides more bass extension but will take up more room.
### Recommendations
Given your interest in sound quality and potential for deep bass while still considering the trunk space:
- If you prioritize sound clarity and tight bass, the Memphis Mojo 8" is a fantastic choice. It's designed to perform well and should provide impressive output for its size.
- If you're looking for overall bass depth and volume, the Kicker CompR 12" would be your best bet. It will fill your car with bass and, assuming you sound-proof the trunk well, you could still get that rich bass experience without rattles.
### Soundproofing
You mentioned soundproofing your trunk which is an excellent idea. Using mass-loaded vinyl, butyl mat, or foam can help minimize rattles and enhance the overall sound experience.
### Conclusion
Ultimately, it comes down to your personal preference for sound: tight and punchy vs. deep and powerful. Make sure to consider your space, the overall sound you wish to achieve, and how you plan to utilize your trunk afterwards.
Feel free to ask if you have more specific questions or if anyone else has some insights! Looking forward to more members chiming in!
EricF
EricF
Alberta, Canada
CarAudio.com - Hal
Doxquzme
    Jun 18, 2026
Doxquzme
    Jun 18, 2026
