What sub should I get?
Jdoghaf
Utah
Hello everyone. I recently purchased a 2004 Chevy Silverado and was pleased to find that the previous owner had already installed an after market radio (Kenwood KMM-322BT) as well as a 5 channel amp (Kenwood KAC-X650D). The sound system is already up to my standard except for it’s missing a sub. What sub would you guys recommend for this amp? I tried looking through the specs, but found that there were different specs depending on if you are using 12v or 14.4v. I tried to determine the voltage by putting a voltmeter on the power terminals but got a reading 26 volts - so I’m a little confused there…
I’m obviously not an expert at this stuff, so any help is appreciated.
I've never known anyone to be pleased with the way the sub performs off the 5th channel of an amp.
Is the truck an extended cab or regular cab
You should already have the wiring there so adding a new sub and amp should be easy
The question is how much space are you working with and/or how much space are you willing to part with
How much bass do you want?
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
935
Have you check to see if the prefab would fit...
13
It's fine to mount to the box. A lot of show car SPL setups have amps or other electronics mounted directly to the wood frame of the box or on an...
21
Not sure on your level of knowledge here. You can wire your sub up 2 different ways, resulting in 2 different resistance (ohm) values. Your amp...
31
4K
120
Jdoghaf
Jdoghaf
Utah
Jdoghaf
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
