Sealed better when trunk open....
solidcrowd
1.) This kid has 2 kicker cvrs in a prefab sealed box. I think its in a stratus, anyways when he opened his trunk and played some rap I could feel it in my chest. Now my enclosure is tuned to 32 hz and when I open my trunk I don't feel anything compared to his. My substage is way louder though inside my car when the trunk is closed though. Can someone please explain why I could feel his in my chest from his sealed box.
2.) Also, I normally played my music around 35/62 when the bass is heavy, but when I open my trunk and play, I am afraid to turn it up past 26..it seems like there is too much excursion. I this cause there is nothing for the air to bounce off?
I don't know if his was louder or quieter when popped, I was just saying when I stood behind his trunk I could feel it in my chest and when standing behind my I dont feel it.
on a simliar topic, i have openings in my rear deck where speakers used to be. do you think i would notice an improvment in bass by sealing those holes?
thread jacker lol...If anything I would think leaving them open would get more air flow into the front
sealed is betta~!
no i dont know for sure bit i used to only like ported boxes till i got a sealed box built to specs and im alot more impressed.
I have two Audiomobile mass 12's in 1 cube each dual chambered box and it suonds to much better (to me) than my L5's ported
Seems sound a lot better on the low notes to.
portd to me sounds good on mostly rap.
build another box and tune higher..
i normally run my 15 in a ported 5cu@30hz FG dual 4" port and i don't feel **** hit my chest.. ever. this on a 1500D
before the 5cu i used a wood box of 4cu@30hz and never felt **** hit my chest with 2 different amps. a soundstream pca2000d and my saz 1500d
well recently last month i felt like blowing a speaker up by strapping 2 1500ds together. well on 12" speaker of same type i made an enclosure of 2cu with two 4" ports tuned to 40-45hz(don't remember). on my way to a Friends house i only had 1 amp hooked up to that speaker. same songs i used to play on the 15" and i was feeling the music hitting my chest.. i was like WTF?? and this is on a single 1500D
now if you have some extra wood or cash try a new enclosure and tune it higher. see if there is a difference for you. or try to build a box with interchangeable ports. that way you could tune around till you find a desired tuning thing a ma jig o boopie.. :/
when i had my SXs first installed facing the rear it was louder with the trunk open. it was due to cancellation that i fixed by sealing up the stupid port the stupid installer put facing the front of the car. he built me a 4 cube sealed. i told him i needed a ported. so instead of rebuilding it he put a single 4 inch port in facing the front and negleted to tell me right away. when i picked it up the guy that actually did the work claimed he hadn't heard about redoing a ported so he continued with a sealed. he says he didnt' know the other guy in the shop put the port in. regardless, the cause of the increase in volume was becasue the sound wave off the sub was leaving the car adn not cancelling the wave from the port.
and having your trunk open doesn't cause more excursion. your subs are fine playing with the trunk open. look at all the roe vids that show people running their systems full tilt with the trunk open.
sealed is betta~!
I would bet my life you wouldn't like sealed better with certain subs. Not every enclosure type sounds the same when varying subs.
This thread is pretty ridiculous.
To the OP, I would bet that if your friend pushed his subs closer to the trunk opening, it would be much louder with the trunk closed. Also, the difference in sound between the two is almost definitely based on the vehicles and cabin gain and not really the enclosure.
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
12
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
9
And you (if you’re not a Ai BOT), for the sake of everyone in this forum, may want to quit posting, Your information is consistently off topic and...
48
7K
They have pre-cut wood if you pay extra at the hardware store. Just draw it out. But you'll have to pay extra. Then screw it in yourself...
7
solidcrowd
solidcrowd
Buffalo, New York
MyFartsStink
winkychevelle
    May 24, 2024
