Help needed audio stops playing
Thevaran Moodley
CarAudio.com Newbie
Hey guys hope you are well I have a bt starsound single din running 4 speakers and 2 tweeters with a monoblock for my two 6inch subs and for some reason after couple minutes maybe 5 to 10min of playing it, the sound will cut off. If u switch the radio off and on it will still not play sound even if u switch the car off, the only time the sound work is when you disconnect the power cables in the back of the din and reconnect it then it will play hundreds and then cut off any idea what's the solution!? Thanks in advance...
Thevaran Moodley
CarAudio.com Newbie
Thevaran Moodley
1 Bransby Place
1aespinoza
