I wandered the same thing I'm thinking space issuesIf it's not a burp box why the 40hz tunning?
Because itll still play low. Every other setup ive done with aq has been tuned to 38 and peaked around 36 or so. I dont forsee any phase issues, ill have all 8 subs mounted above the port with the port on the bottom. Nominal load will be .5 ohms, going to be running one big amp for now. I will test it on my brothers crescendo 5500 then hopefully get a ct sounds 7000.If it's not a burp box why the 40hz tunning?
Its very very close on space, each 10 will see 1.2 cubes net tuned to 40hz with 21.375" port area. Im guessing this setup will do a 153+ easy in the high 30hz range at the headrest. I helped my friend do a similar build with 5 sa 10's and it was doing 151's at 35hz with 3kw and the wall not fully sealed from the back of the car.I wandered the same thing I'm thinking space issues
We were wandering why you tuned so high for a daily setup?Its very very close on space, each 10 will see 1.2 cubes net tuned to 40hz with 21.375" port area. Im guessing this setup will do a 153+ easy in the high 30hz range at the headrest. I helped my friend do a similar build with 5 sa 10's and it was doing 151's at 35hz with 3kw and the wall not fully sealed from the back of the car.
Lol it looks intense. I got the box in the car after i took my door off. I got it hooked up on a kicker 200.4 and honestly it was pretty loud not even sealed off at all. These subs are very efficient. Even on like 30-40 watts a piece they were movin. Gonna put a saz 3000 on it tonight and hopefully itll bang. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifthats just insanity in box!!!!!!!!!!!!!!!!
