Gain Setting Tutorial
Are you in the proper range?
Call me crazy, but in this thread dedicated to setting gains, I find it a bit odd that you are trying to get your multimeter to read 40 volts. What are you trying to do?
Set his gains...//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif.
Either your not turning your gains up, you don't have your dmm ranged properly, or you need a new dmm.
Yes I did turn my gain up but i was just wondering if the V with the wave above it is the symbol for AC because thats the symbol on the dmm.
This is a link to my multimeter http://www.canadiantire.ca/assortments/product_detail.jsp?FOLDER%3C%3Efolder_id=1408474396670087&ASSORTMENT%3C%3East_id=1408474396670271&bmUID=1130801331490&PRODUCT%3C%3Eprd_id=845524442202179&assortment=primary&fromSearch=true
If I got two subwoofers and I want each sub to get 1,000rms @ 1ohm do I do 2,000rms x 1(ohm) then get the sqrt of 2,000 which is 44.721. Correct?
Uhh...2 DVC 4ohm subs running at 1 ohm? If you're talking about dvc 2 ohm subs and running each at 1 ohm you would have a final load of .5 ohms with the 2 combined.
SirClay
President
SirClay
Texas
Tek18
NorthFramingham
    Jun 30, 2026
