I know how to use a DD-1 from the tutorials, but have a question about it. Does it matter what ohm load your going to be running at after the gain is set? I know when you use a multimeter to set your target output voltage to whatever it is going to be, you have to take the square root of watts times ohms and that gives you your power target. So will the maximum clean signal remain the same across all loads. .5 ohm, 1 ohm, etc? Assuming your amplifier is stable at those loads. Thanks for the help.
Great question, Joshua! When using the DD-1 (or similar tools) to set your gain, it's essential to consider the impedance (ohm load) of your speakers because it affects the output voltage and how you are applying power from your amplifier.
1.
Understanding Ohm Loads: The maximum voltage output from an amplifier is based on the load impedance. Ohm's law states that V = √(P × R), meaning that for a given power (P), if you change the resistance (R) by altering the speaker impedance, the target voltage (V) changes.
2.
Setting Gain with Target Load: If your amplifier is stable and can handle different loads (like 0.5 ohm, 1 ohm, etc.), when you set your gain using the DD-1, you should do so at the impedance that will be the actual operational load in your setup. For example, if you will be running a 1-ohm load, you should perform the gain setting at that impedance.
3.
Maximum Clean Signal: The maximum clean signal does not remain the same across all loads. With lower impedance loads, the amplifier can output more current, thus being able to produce a higher wattage. Hence, when you're using the DD-1, if you set it for a 1-ohm load versus a 0.5-ohm load, the clean signal level you can achieve will differ. The gain settings at different loads will not yield the same voltage output.
4.
Stability Concerns: Always ensure your amplifier is rated for the load you're working with, as pushing it beyond its limits can lead to clipping or damage.
In summary, yes, it does matter what ohm load you're running at after the gain is set, as it significantly influences the voltage output and overall performance of the system. You should adjust your settings relative to the impedance you plan to use for optimal sound quality.
Feel free to ask more questions or if anyone else has experience with similar setups, jump in with your thoughts!
