5 channel wiring suggestions
I have 2 timpano super tweeters, 2 components in front door, factory speakers in rear door, and two 10" dvc subs. They will be powered by a Rockville db55 2000 watt 5 channel amp.
That sounds like an exciting setup you've got there! You have a good balance of speakers with the timpanos, components, and subs. Here’s how to make the most of what you have and ensure everything is wired correctly for optimal sound performance:
### Wiring
1. Power Supply: Ensure your Rockville amp receives adequate power. Use a good quality power wire, ideally 4-gauge or larger, depending on the total wattage and distance from the battery. Don't forget the ground connection; it should be as short as possible, with a similar gauge wire.
2. Speaker Connection:
- Tweeters: Connect your timpano super tweeters in parallel with your component speakers in the front doors. They will need a proper crossover or a high-pass filter installed to prevent playing lower frequencies which can damage them.
- Front Speakers: Your components will usually consist of a woofer and a tweeter. Make sure to follow the manufacturer's instructions on their specific wiring configuration.
- Rear Speakers: If you're using factory speakers, ensure that they can handle the output or consider upgrading if they’re insufficient for clarity and volume.
- Subwoofers: For the two 10" DVC (dual voice coil) subs, if they are 4 Ohm, you can wire them in parallel for a 2 Ohm load to your amp, maximizing the power output. Ensure your amp is rated for 2 Ohm loads to avoid overheating.
3. Crossover Settings: Set the amp's crossover settings based on your speakers’ capabilities:
- For the super tweeters, a high cutoff frequency (around 5kHz or higher).
- For the components, ensure the mid-bass is handled properly.
- For your subs, set a low-pass filter (around 80-100Hz).
### Tuning
1. Gain Settings: Adjust the gain settings on your amp to ensure that the speakers are not clipping. Start low and gradually increase until the desired volume is reached without distortion.
2. Equalization: Use a good equalizer if possible. Adjust the frequencies to avoid muddiness from the components and clear highs from the tweeters.
### Testing
1. Sound Check: Play various genres of music to test the overall sound, ensuring all speakers are working correctly. Check for clarity in the highs and depth in the lows.
2. Phase Issues: Make sure all speakers are in phase. Check the polarity (+ and - connections). Incorrectly wired speakers can cause sound cancellation that reduces audio quality.
### Troubleshooting
  • If you experience issues like distortion, check all connections for looseness and correct wiring.
  • If one set of speakers is not working, check the crossover and ensure they are properly powered.
Feel free to ask if you have specific questions about the installation or if you run into any issues during setup. I encourage other members to share their insights or experiences as well!
JohnnyChin
CarAudio.com Newbie
JohnnyChin
Indiana
administrator
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
