building a box
Enclosure
  • Sealed
    Votes: 2 14.3%
  • Ported
    Votes: 12 85.7%
  • Total voters
    14
30 ftw? LOL so im guessing 30+ FTL. **** i don't know how to find out how to tune my box or how big to make it :[ is there a calculator online or somethin for that stuff??
id suggest about 29-30hz. you want loud but its gonna be louder around 35+ but its not gonna be low. tuning lower gets you better sound quality
very true. WELL CONSIDERING i just got my front stage hsk165's i'll tune it to 30 hz because im lookin for SQ now. because i actually have very nice music coming out of my front stage
IDK. i can't decide. i already have a ported BOX. should i just make a better ported custom enclosure or go totally different and make a sealed enclosure??
and so i hear
Enclosure Recommendations
Sealed Enclosure: The G2124 woofer is optimized for use in a small sealed enclosure with a 1.0 cu. ft. internal volume.
Ported Enclosure: The woofer can also be used in a 2.0 cu. ft. ported enclosure with a 4" diameter, 13" long port, and tuned to 34Hz.
and when it says "recommended enclosure", are they referring to ONE sub or TWO??
and i also noticed it says tuned to 34?
SHOULD I STILL TUNE IT TO 34?
or tune it to a perfect 30, like you all have said??
VB-Volume of Box
Recommended Enclosure should be for each sub.
Tuning depends on trunk size,air space,deadening,etc.... Porting can tricky, you cant have a big box & not have enough air for the port to breath right.
take one project at a time
i use the re box builder just type in the dimensions and it tells you what cuts to make and all the info on it ported is what i do. and i coat mine in bed liner i like the look
The crossover is just a pair of 3way, 300watt crossovers I picked up from from amazon. the subs I have are 8" Kicker FreeAir f8a I am looking...
816
Build currently on hold, waiting on a custom voice coil. The former isnt tall enough for the new setup. On the plus side the motor has 3.25" of...
30
4K
dafobbishon3
dafobbishon3
Texas
okiedokie
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
