building a box
Enclosure
  • Sealed
    Votes: 2 14.3%
  • Ported
    Votes: 12 85.7%
  • Total voters
    14
sweet, ill look that up online. but idk how i'd want my dimensions of the box. should i just do it so it'd fit the inside of my trunk all snug.
if you get high tunes, they are just going to sound loud, and all boomy, then it starts to distort.
with low notes. it sounds very clean. especially if you have a good front stage. then it'll all sound very nice.
if you get high tunes, they are just going to sound loud, and all boomy, then it starts to distort.with low notes. it sounds very clean. especially if you have a good front stage. then it'll all sound very nice.
So where does cabin gain come into the equation then? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
are you talkin about the cabin gain from the amp?
Nope, gain from the cabin of the vehicle. Take a sub an enclosure, listen to it outside of the car. Throw it in the car and listen. Notice anything ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
of your trunk!
what type box are tyou going to buit??
What type of ports are you looking at????
you need to make sure you have enough room for your ports to breath & you dont want your sub flexing against your trunk, just make sure you enough room for the box,subs & ports.
plus you'll need to deaden your trunk also, YES your trunk does & will flex. which to me with it deadener your bass will sound like a tin can booming, some guys like that tin can flex
if you do it right it will it low & your sides will fex but not like a tin can.
are you going to work on your sub box or front stage first?????????
take one at a time or you'll find yourself in a mess.
YES there is a lot to learn about car audio & your car.
YEAH i think thats my PROBLEM. cause everyones custom boxes subs, i hear, they are LOUD, and i hear NO RATTLING IN THE TRUNK. but in MY CAR. i can't even HEAR MY BASS that much because ALL I HEAR IS SHITTT TRUNK RATTLING. maybe a custom box will help? idk. my trunk sounds VERY BADDD.it sounds worse than the tin can boooming. so maybe i should do the box?
the box, is goin to be rectangular, using 3/4 MDF, rectangular ports,
but that the thing, idk how to determine the air space, how big to make the box, the port, all that non sense. how to tune the port. :[ but i think if i do have the RIGHT CUSTOM BOX, it's going to sound very nice.
im still debating. I REALY NEED TO FIX MY FRONT STAGE cause im taking it to the shop that i bought it from on friday. to see if theres problems because there is over heating. when gains are +1/2 so idk
idk between deadening and rings,
or
custom box for subs. :\
yeah. its GREAT.
really? 4 cubes to 33??
i was thinkin about doin the 4 cubes. but idk which to tune it at.
im hearing 30.
the website says 34.
how does 33 sound?? && what music do u listen to?
really? 4 cubes to 33??i was thinkin about doin the 4 cubes. but idk which to tune it at.
im hearing 30.
You wouldn't notice a difference between 33 or 34hz tuning. Probably wouldn't be able to hear a difference between 30 and 34hz. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
im hearing 30.
just rap. in a cavalier they did a 140.3 in that box off of an overrated power acoustik amp. then i switched to sub up port back with a flared port and it was even louder but it was still 4 cubes at 33hz
dafobbishon3
dafobbishon3
Texas
okiedokie
