okiedokie
there this guy named PETE KUKICKI- http://www.pwkdesigns.com/index.html
pete designed a box for me once, he probably will be your best bet.this guy knows his shit.
if boston acoustics recommendations is 1.5 for ported for that sub i woudn't go to much bigger.
people tell you what worked for them in a SPL loudness, but if you want more of SQL which you can get out of those subs , i would call boston up just make sure that you wnt burn out the voice coil or burn any tinsel leads with to much air.
company has a recommented box size for a reason, you just cant say that you want to put a 12 into a 2,3,4,or 5 ported cubit box without really knowing the specs on your subs or speakers..
I had A Re SE that i burnt out tinsel leads on it, I listen to what other had did with there SE, & it didint work for me.
so be carefull, unless if you have to blow on subs.
if your'e going to do ports you could look into these????
http://www.diycable.com/main/product_info.php?cPath=24_93_150&products_id=583
Probably easier to tune your box to.
these ports are 4inches round, so make sure the port is 4inches from the wood or sides.
& at least 4 inces from the back for air flow.
this is basic, ok
If you dont deaeden your trunk no matter how great your box is, you will still get that tin can sound, it comes from your trunk not your box.
builting a better box, with double up the wood or bracing it , or even fiberglassing the wood will help deaden the box not the trunk.
what do you mean the by over heating??
you amp or speakers???
this is basic, ok
