Featured Newbie Seeking Help with Audio Configuration
I currently have a Kicker compR 12 wired 2ohm on a 1000w monoblock and it rocks with deck power on the hi's... /w/ amplified hi's a 4 ohm setup from one of those mini 1ohm amps is going to lack, no question. His signal chain is one thing and yes... it may be needing attention
That statement alone begs questions. No series or parallel?
How TF is that accomplished with an SA classic?
Its like Forrest Gump... he cant see the trees because the forest is in the way.
No shade thrown btw... I've been doing this for almost 5 decades.
5 decades??? Geez
I guess time does fly I'm nowhere near that old but playing with car audio 25 years now and it feels like yesterday when I bought my first woofers
Well if the classic is wired at 4ohm load
He should have a dual 2 ohm driver wired in series
He can just rewire the sub in parallel for 1 ohm
That amp dyno's around 1300 watts to clip at 1ohm
Plenty of juice for that classic to dance 🕺
Even if he's mistaken and has a dual 4 ohm driver and is wired to 2 ohm load that amp dynos at 1000 watts
Unless someone wired his dual 4 ohm driver to 8 ohm 🤣
Ok not giving up yet again just tired lol! Should I rip open the sub and take pics so you can advise if it is wired as 4ohm or whatever and or should I rewire? Thank you all truly appreciate it. Actually if anyone is down to jump on a FaceTime quick call when I am in front of the car and take a quick looksie I can pay for the time if you want for the diagnostic help if it yields a successful outcome (side note so should I get a new amp and if so what recommendations for the mono amp) number is 972 972 0878
Don't sweat it take your time
Look at it like a hobby just play with it on your spare time
We aren't going anywhere
Do you have a multimeter? Or can borrow one?
So based on the current sub amp I am running I’ve spoke to a few installers and they mentioned it is plenty to power just the one 12 I have but they advised it needs to be wired correct to have the correct output bla bla bla - below are the spec on the amp - I will open the box and see how buddy wired it and hopefully get more insight how it should be wired..
Technical Specifications:
Power Ratings:
  • 1 ohm: 1000W x 1
  • 2 ohms: 850W x 1
  • 4 ohms: 550W x 1
Frequency Response: 10Hz - 264Hz
Low Pass Filter: 35Hz - 250Hz
Subsonic Filter: 10Hz - 50Hz
Input Sensitivity: 6V - 0.2V
Signal to Noise Ratio: >95dB
Total Harmonic Distortion (T.H.D): <0.1%
Operating Voltage: 9V - 15.5V
Fuse Rating: 100A
Speaker Wire Input: Up to 12 gauge
Power and Ground Input: 4 gauge
You don't need to remove woofer just yet if you have a multimeter you can measure the ohms off the speaker wire
If it measures 4 ohm then it's probably a dual 2 ohm coils and you can decide to remove driver to wire down to 1 ohm if you wish
Ok so if I scrap this amp and donate it to charity will the following do!?!! Heading to Best Buy since I have the total tech membership which allows me to return delinquent audio equipment should that issue arise :alien::sick:
Specifications​
Alpine Class D MONO 1800W (is also on sale for $400 - Open to suggestions as always doesn’t necessarily have to be big brand name etc etc although I do miss the OG Alpine Gear we used to have back in the day IYKYK V12 etc lol
  • Continuous Watts x Channel @ Ohms
    900 Watts x 1 @ 4 Ohm
    Maximum Watts x Channel @ Ohms
    1800 Watts x 1 @ 2 Ohm
    Amplifier Class
    D
    Number Of Channels
    Bass Boost
    Variable
    Low-Pass Crossover
    Variable
Ok I will check shortly let me pick up a multi meter - so you mentioned “down to 1 ohm if you wish” what will this achieve and what are the benefits, sorry for the silly questions I have never owned a dual voice coil sub that has so many ways to be wired to be quite frank lol. You have been super helpful with this thus far and truly appreciate the support, chat GPT is not the best option here to rely on !
Specifications​
    Amplifier Class
    D
    Number Of Channels
    Bass Boost
    Variable
    Low-Pass Crossover
    Variable
Your amp should be fine for that woofer
Unless ur intention was to rattle stop signs?
That woofer is rated at 750 watts rms
If your woofer is a dual 4 ohm coil
You can wire it down to 2 ohms and you will have more than rated power for that woofer about 1000 watts on tap
If your woofer is a dual 2 ohm coil you can wire it to 1 ohm and you will have even more power
You should be OK
OK good to know
Now with a multimeter ur going to test the resistance on the speaker to see how it's wired internally
When you have a chance unplug the speaker wires from the enclosure
Put the multimeter oh ohms
Put red lead on positive terminal and black lead on negative terminal
Then get back to us with the reading
Not possible if it is a dual 2 ohm driver
Did you measure from the terminals on the speaker box?
Only way it will measure 2 ohm is if 1 of the coils isn't connected inside
hektikm6
hektikm6
Dallas Texas
shredder1
