MTX Terminator sub kit stopped working
  • 2
Brentlucas26
Hey I was wondering if anyone could help me with my subwoofer kit that stopped working out of nowhere.
Subwoofer: Dual 12” MTX Terminator subs
Amp: MTX Thunder 500.1
Wiring: Standard wiring with terminator kit
So when I turn my car on the amp light comes on and turns off immediately and the protect light is off. I tested the voltage of the power wire while not hooked into the amp and it’s 14V....when the wire IS plugged into the amp it only reads ~2.5V...not sure if that’s normal or not. Any help would be greatly appreciated, I’ve spent hours trying different fixes from online and nothing works.
Thank you In advance!
Check all power connections. Clean and tighten all connection points, refreshing contact points is always a plus even if you switch the amp out. Before all that, I would connect the amp next to the battery to see if it stays on. Neg to neg, pos to pos, and a short wire from pos screw to remote screw to turn it on. If it stays on, the likely culprit is your wires/fuse.
Ok thank you I’ll give it a try and let you know!
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
672
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Brentlucas26
Brentlucas26
Ny, USA
Brentlucas26
    Apr 26, 2024
    Apr 26, 2024
