DSP install help
LMJexploder
CarAudio.com Recruit
I'm installing a audio control DM-810 what is the best way to connect it with the head unit? I have a Kenwood DNX-997xr . Should I use the Front and rear and sub rca outs from the head unit or speaker level inputs I have heard both ways but not sure. Looking for the best way to do it. Also I have the epicenter from audio control do I put that before or after the dsp ? Or will the dsp do the work of the epicenter and I won't need that? And then from the dsp I just run 1 set of rcas to the sub amp and 2 sets to my 4 channel amp correct. Any help or advice would be greatly appreciated. Thanks
Theres a lot to do with a dsp. You got a huge learning curve ahead of you dude.
Get rid of the epicenter, too many things in the signal line will cause major distortion and clipping, you ll blow your shit. Do the RCA route.
LMJexploder
LMJexploder
Seattle WA
Jeffdachef
