My first "Active" "SQ'ish" build attempt.
www.resonixsoundsolutions.com/reference-information
long story short, outer skin needs zero. Inner skin you should be doing 100% coverage
Actually, I am glad you took the time to point this out to me. I do have some rattles that I didn't have before. I don't think it is going to harm anything having the CCF inside the door and that stuff is pretty much a permanent part of the door now so I will not attempt to pull it out. I will however order some more CCF and do the doors 100% or 98%. I swear... the yellow flies were relentless and I have no tolerance for biting flies. So I did rush. I will fix it.
What the hell are yellow flies?
These little spawns of Satan!!
I don't know why but tonight while at work I decided to lower the back seat backrests opening up the cargo area. All you can see is the sub box, the speaker connection and a small gap on either side of the enclosure. Bass response is better and there are less rattles in the car.
Ummmm duhh
The umm1 is just a rebadged dayton/minidsp mic. I personally have a umik2 and use a regular usbc-usbc to hook it up to my laptop and a...
119
855
https://www.alpine-usa.com/products/subwoofers/truck-enclosures
974
As for your setup, the circled input in that reply is where the LOC (built into the amp) is located. You don’t need a LOC other than that. All you...
35
4K
741
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
ThxOne
