My first "Active" "SQ'ish" build attempt.
www.resonixsoundsolutions.com/reference-information
long story short, outer skin needs zero. Inner skin you should be doing 100% coverage
Actually, I am glad you took the time to point this out to me. I do have some rattles that I didn't have before. I don't think it is going to harm anything having the CCF inside the door and that stuff is pretty much a permanent part of the door now so I will not attempt to pull it out. I will however order some more CCF and do the doors 100% or 98%. I swear... the yellow flies were relentless and I have no tolerance for biting flies. So I did rush. I will fix it.
What the hell are yellow flies?
These little spawns of Satan!!
I don't know why but tonight while at work I decided to lower the back seat backrests opening up the cargo area. All you can see is the sub box, the speaker connection and a small gap on either side of the enclosure. Bass response is better and there are less rattles in the car.
ThxOne
Premium Member
Staff Member
ThxOne
The United States of America
ThxOne
michigan born
    May 14, 2026
michigan born
    May 14, 2026
