wiring 2 amps in a altima
  • Thread starter Unregistered
  • Live activity
  • Replies 1
  • Views 892
U
Unregistered
Guest
i have a 200.2 autotek running a jl w3. and i want to put in a rockford fosgate punch 45 x2 for some speakers.
how do i wire this?
2 sets of rca
1 remote lead
any tips for me would be appreciated
ok you'll need to run a power wire lead from the battery usually an 8 gauge wire will suffice for the power lead...also you will need about a foot and a half of 8 gauge wire for a ground wire...also you will probably need about 14-18 gauge wire to go from the amp to the speakers...everything else should pretty much and put a fuse about 6 inches from your battery so you can prevent a surge in power depending on what gauge wire you have for your power lead that will determine the size of the fuse you need. hope that helped you more than confused you
Guest
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
