wiring 2 amps in a altima
  • Thread starter Unregistered
  • Start date
  • Replies 1
  • Views 649
    Participant list
U
Unregistered
Guest
i have a 200.2 autotek running a jl w3. and i want to put in a rockford fosgate punch 45 x2 for some speakers.
how do i wire this?
2 sets of rca
1 remote lead
any tips for me would be appreciated
ok you'll need to run a power wire lead from the battery usually an 8 gauge wire will suffice for the power lead...also you will need about a foot and a half of 8 gauge wire for a ground wire...also you will probably need about 14-18 gauge wire to go from the amp to the speakers...everything else should pretty much and put a fuse about 6 inches from your battery so you can prevent a surge in power depending on what gauge wire you have for your power lead that will determine the size of the fuse you need. hope that helped you more than confused you
Just ignore Red...he's wealth of useless to dangerous advice...all without knowing what he's talking about
19
You can try that Seat Bolt for a ground location. Remove all paint down to Metal. Place a Washer then One amps ground Ring terminal(copper..sand...
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
218
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
622
Guest
