TEAM DEAF BONCE USA - (2) 32s | 48kw | 48 banks of caps
Sorry, I've been away and left you all without an update, but here are some older photos. I'll get this thread caught up within the next few days. We ripped apart the interior and started working on the cage. As the last photo shows, the old recones*take up the entire side to side space, which means this will be an interesting configuration.
Once cleared out, we started to work on the shell. We used 2"x1" steel. We elected to not go over the wheel wells in order to keep the rear AC and hopefully cool all the amps in the rear. We'll also have to mount the amps in some different positions because of the*number of caps used. Anyways, here are some pics of us stiffening up the roof with 3/4" wood in between the stock slots (kerfed to contour) and then about 10 cans worth of about 3/4" foam between the wood and cage. It's not as stiff as the Alpha's roof, but it is a lot better than stock.*
Nice!! Solid steel or tube steel? If it's solid, that's a ridiculous amount of weight //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Sorry for the lack of updates. We've just been busy. The inside of the cage is complete with sides and top. We used angle iron to get the angle of our baffles and used some massive bolts to secure the iron to the cage. The excess PL is just to make sure that the bolts don't back out LOL. We elected to use 1" trim pieces to make sure that the sides, top, bottom are 100% sealed because there were just some minor gaps in some areas. We traced the sub cutouts using a yardstick LOL. The subs fit perfectly in test fitting on the grass. But now one baffle is completely mounted. Things are coming together.*
Here are the 48 banks. These are not the newest version from Maxwell, but we consulted some close friends and figured that they'd still be a great option for this build - especially when it came to weight savings vs. AGM and cost savings vs. lithium.
may i suggest fiberglass battery box?
Owned this sub long enough for a review now.gets those lows really well.stout sub.love it.puttin around 3k watts rms on it.my ears will fatigue...
24
4K
Some of the NVX stuff seems alright, but the amps, especially the higher end ones, they seem suspect and sometimes show stats that straight up say...
13
4K
There probably isn’t a huge difference in some of them with displacement. It matters more with the smaller boxes and smaller subs. The smaller the...
Does anyone have any experience w/ either of these? Its looking like more and more that I won't be running a sub and/or it will be a long time...
ObTechAudio
ObTechAudio
Provo, UT
ObTechAudio
Brendon Jenness
    May 8, 2024
    May 8, 2024
