OP
a 10x13x13 box is only .65Its probably The bottom is 10x13, minus 3/4inch for the wood all around, and it is 13 or 14 inches high
Need length height and width.Its probably The bottom is 10x13, minus 3/4inch for the wood all around, and it is 13 or 14 inches high
that would be .82Actually, probably 16" or so high
You're not even at a cube with that after displacementActually, probably 16" or so high
This^^^that would be .82.72 after sub.
what are your exact dimensions?
somethings wrong in your equation i think your missing a variable. your outer dimensions areI don't understand the calculation the computer did for you, 12^3 is 1728 and my multiplication was 1728 and some change. I'm not sure how that equals .82...?
That calculator deducts the 3/4 all around and gives the interior volume.I don't understand the calculation the computer did for you, 12^3 is 1728 and my multiplication was 1728 and some change. I'm not sure how that equals .82...?
10x16x13. minus 3/4 inchThat calculator deducts the 3/4 all around and gives the interior volume.
even if it is 1cubic ft no you can't use it so as stated above toss it and get a new one. use sundowns specs or get one built by someone as your math isn't all thereWe can figure this out later lol according to my calculations I have a cubic foot box. Which is double to what I need. And I'm gathering that this can't be ported by cutting a hole in it, so I must need a new box then...
