Setting gain with DMM
darkhunter139
I just got my new diamond 800.1 amp and I am trying to test it out right now.
When I have the gain all the way up I am only getting a 24.4 AC reading. This amp is suppose to do 800 watts at 1 ohm which would be 28.28 volts
Am I doing something wrong or what?
Yeah vechicle is started and all connections are good.
I am only using 8 gauge power wire at the moment could that have anything to do with it? (Well actually it wont even reach the 300 at 4 ohm its suppose to so I dont think thats it)
yes, what tone are you using and aslo, what is the pre-amp output voltage of your hu? of course the volume of the hu needs to be about 80%or so and you sub level on the hu(if you have one) should be 80%also.
sub level is all the way up. pre amp output voltage of my head unit? No idea but I know my old 500 watt amp got the correct readings.
are you using the remote level controll? some amps, when using the remote, need to have the main gain up allmost all the way but iam not shure about that one. what is the range of the low input selector?(ie-250mv to 5v)
Just went out to test it again and it got readings of 60 volts when I had it turned all the way up lol
Must have been doing something wrong the first time.
Is there a way to find out how high I can push this amp without clipping? I have been told its most likely under rated
darkhunter139
darkhunter139
PA
darkhunter139
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
