AudioQue 2200D wiring question
Harleyfx69
audio n00b
looking to run two of the aq2200d's ,
When running these amps as master / slave ,
Is it still stable down to 1 ohm, or would it be 2 ohm stable ?
also doing this, would wiring one amp to each sub be how it works,
or how would that work ?
then for gains and boosts, the master control amp would override the slave ?
do i have this correct ?
When running two as master/slave they are 2 ohm stable but you make twice the power as a single amp @ 1 ohm
When bridged the pair of amps works as a single amp with the master amp controlling everything. Do not run a pair of bridged amps with each amp wired to a single sub when running a pair of subs.
What's the impedance of the subs? You might be better off running a single amp to each of the subs instead of bridging the amps.
k that makes sense,
they either come with 1 ohm DVC or 2 ohm DVC ..
each sub has 1000 watt recomended , and 2000 max
Harleyfx69
audio n00b
Harleyfx69
arizona
Harleyfx69
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
