newbie speaker install help please
ok thank you, i was planning on getting at least 25 feet. will you look at these to sketchs and tell me if one is better/safer than the other please? i would prefer to use the top sketch because it would be less wire(pic doesnt depict this lol).
this way?
or this way?
do i need to run a ground from the rear battery to both amps or just one like in the picture?
Run dedicated pos and negative wire from front to back battery. Then rin dedicated pos and negative wire from battery to amp. Plain and simple. Eliminate chasis grounds completely. You have a friggen 2nd battery, none of that chassis sh*t matters.
ok thx jeff. ive been looking at possible areas to run my power and ground cables inside and theres no way its fitting under my door trim. was thinking about running it under the car and it would be about 25 feet or so. would you recommend stepping up to 2/0 then running 1/0 from a distribution block near the amps?
if you havent bought the wire yet, then yes go 2/0 welding.
Front batt to rear batt dedicated pos and negative runs.
No distribution block needed, your 2nd battery is your distribution block. You want everything wired straight up to the second battery so it can feed the amps the current the amp draws properly.
You arent gonna draw anywhere near 390 amps. you'll be lucky drawing half of that. on paper is different than real world.
ok and how many fuses would i need? do the dedicated runs from front to back batt need a fuse near both battery's so 4 fuses total?
FYI, apparently the new soundstream tn900.4's are not the same as they were. There is a new thread that talks about this (started today) so hopefully you got the older board. Where did you purchase yours?
ordered from amazon and it arrived today, here is the link https://www.amazon.com/Soundstream-TN4-900D-Tarantula-4-Channel-Amplifier/dp/B009NLNY14/ref=sr_1_1?ie=UTF8&qid=1523080897&sr=8-1&keywords=soundstream+tn4.900d&dpID=41RVSF8uDxL&preST=_SX300_QL70_&dpSrc=srch
i have the amp in my hands now, how do i know if its the old or new version? only negative thing i can say is that it didn't come with the 4 gauge to 0 gauge reducers that it says it does online.
[quote name='Clifff150']FYI, apparently the new soundstream tn900.4's are not the same as they were. There is a new thread that talks about this (started today) so hopefully you got the older board. Where did you purchase yours?[/QUOTE]
@Jeffdachef here are the insides of the amp, I'm assuming i got one of the new crappy ones?
@Jeffdachef hey man, so its gonna be a while before i can install my high output alternator due to it being buried in the engine compartment. is there a way that i could use the stock 110 alternator for my two amps? i would just keep the gain and head unit volume way down correct? i would still run dedicated 2/0 power and ground runs.
cparker2591
albany, OR
Jeffdachef
