Initial DSP 408 Setup
  • 4
I'd actually take out a piece of paper and draw/write things down in a diagram thats easy for you to remember and reference. I get messed up sometimes too since i do a lot of these dsp installs, they all jumble up in my mind.
i mean you cant really give up because of something like that man lol. Look on the bright side, at least you can get good sounding silk dome tweeters now. or some ring radiators
I'm stuck with the Pioneer Tweeters. That's what I designed the speaker pods for. I bough
I'm still running the Pioneer tweeters. I designed the speaker pods for them. I designed the speaker pods for them.
Do you like these? Only 80 watts rms. I would run them off the Taramps DS250X2 and then run the Pioneer Pro 6.5 and the ABVFL65MB off of the Taramps DS800X4. Thoughts?
you didnt list anything.
If you have them ordered then theres not much to change. Just dont crank anything up until you are 100% sure the right crossovers are in place.
Also on your tweeter amp channels, turn the high pass on and put it around 500 - 1000hz just as a 2ndary buffer.
My buddy chris likes those rs28s in his mustang. I think it'll be fine
I already ordered the Pionerrs and some Pac Bass blockers. If they sound like crap, then, I will order the Daytons. What should I be setting my Bass amp at crossover wise? And, what should I be doing at the HU with the Bass crossover and subwoofer level. The gain is only about 1/3 at the most right now. The pressure in that little car is pretty intense.
No. Unfortunately, this seems to be a common issue with the Jensen Car1000. I have one that is less than a year old that gets stuck some days. I...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
681
456
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
431
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
Bobbytwonames
slater
    May 2, 2024
slater
    May 2, 2024
