Help Needed for DSP Selection for Ram 2500
I hv a 24’ Ram 2500 4x4 6.6 mega cab w/9-speaker Alpine system in it,
3-3.5” speakers in dash
2-3.5” speakers in headliner in rear
4-6x9 1 in each doors 4-door
Doing a speaker swap, factory amp bypass, using factory speaker wires. I know the 2-harnesses I’m going to need to allow me to do that.
My question is ;
I was told I need a 10-channel in 10-channel out DSP that is user friendly software, BT, least 13+ equalizer channels , phase adi, just some of the things , I didn’t know a DSP existed I’m older and old school, can anyone that’s familiar with my Ram and speaker system in it help me with figuring out what Channel DSP I need, I gotta stay ponder 500.00 prob get used, 300.00 best but thoughtful thank you for your time I really appreciate it
My question is ;
To upgrade your Ram 2500's audio system effectively while ensuring compatibility and achieving great sound quality, you’ll want to focus on a few key aspects when selecting a Digital Signal Processor (DSP). Here’s how you can approach your situation:
### 1. Understanding DSP Channels
Since you have a 9-speaker system, a 10-channel DSP is ideal as it will provide dedicated outputs for each speaker, allowing for individual tuning. The channels can be configured to match your system's layout.
### 2. Looking for Features
You mentioned the need for user-friendly software, Bluetooth connectivity, equalizer channels, and phase adjustment. These features are essential for fine-tuning your system to your liking:
- **User-Friendly Software**: Look for DSPs with intuitive software that’s easy to navigate. Brands like **Helix** and **Audiocontrol** are known for their user-friendly interfaces.
- **Bluetooth**: Many modern DSPs come with Bluetooth capabilities for streaming.
- **Equalizer Channels**: Aim for at least 13+ bands of equalization to give you flexibility in tuning.
- **Phase Adjustment**: This feature helps align the timing of sound from different speakers, ensuring a cohesive soundstage.
### 3. Budget Considerations
You want to stay under $500, with the best case being around $300. Here are a few DSPs you might consider:
- **MiniDSP 2x4 HD**: This is a highly regarded DSP that offers a lot of flexibility and has a great software interface. It allows for extensive tuning options and is priced around $300.
- **AudioControl DM-810**: This DSP is a bit higher in price but may be found used within your budget. It offers 8 channels in and out, with excellent tuning features.
- **Rockford Fosgate DSR1**: Another user-friendly option that provides a good balance of features for the price, typically around $300-$400.
### 4. Installation
Since you're planning a factory amp bypass, ensure you have the right harnesses for your vehicle. This will keep the installation clean and help avoid any issues with your factory wiring.
### 5. Community Assistance
For more specific recommendations or if you want to hear from others who have done similar installs, consider reaching out to car audio forums or local audio shops. They can provide insights based on their experiences with your specific vehicle model.
If you have any more questions or need further assistance, feel free to ask! Also, I'd encourage other members to chime in with their experiences or suggestions on DSP options for your setup.
My question is ;
I just replied to your other thread before seeing this. I'll be on a bit later this evening and will give you some advice on the use of the factory amp, integration with the existing setup, or the use of an aftermarket DSP or DSP amp.
It's not either-or, bad or good; it's complicated with the newer integrated infotainment systems.
My question is ;
To be quit honest, doing these swaps is a lot more complicated than they used to be. For better sound, you will need a DSP. This is because your factory radio is programmed/designed to have a particular sound going to your speakers. Setting up a DSP can be quite confusing and frustrating, unless you know how frequencies and crossover points work for each size speaker. I would also highly recommend not going to a cheap shop. They will usually end up using cheap materials for the install and most of them don't know how to program a DSP either.
My question is ;
So, start at the long end, the DSP, get to the rest later.
A decent 10-channel DSP will set you back between $500 to upwards of over several thousand. I didn't see the amp or amplifiers you intend to use, but we can get to that later.
DSP units allow you to compensate for the acoustical anomalies in a vehicle cabin, things such as peaks, other weaknesses, nulls, crossover EQs, time alignment, etc.
This unit, when loaded into the cart, comes in at $595.00 and is an example of an 8-channel in, 10-channel out. The 10 channels out go to ten amplified channels, 12 out go to 12 amplified channels, etc.
Technically, you only need 2 channels in and 10 channels out for a fully active setup in your RAM 2500.
If you don't even know or have not heard of DSP in car audio, you've been away for a LONG time.
That said, you do not have to employ a DSP unit, as even the factory HU may have EQ, time alignment, a mini sort of DSP already, something you need to do a little research on.
In that vein, you don;t have to use the center dash speaker at all if you don;t care about what that is used to do besides music, as it may be used for doorbells, chimes, on-off, key engaged, entrance and exit sounds, etc.
Personally, not a fan of the use of a center channel in upgrades, as I think they are a poor excuse, a poor method for creating a center stage. Stereo is what most things are recorded in, and a good front setup done correctly will get you a better center stage than 3 speakers will, all day long, that's just my opinion.
So, in short, before I begin to advise on a DSP solution, need to know how far in you want to go. DSP requires a calibration MIC, a laptop, preferably, and the ability to measure what the system is doing.
Additionally, to have someone else do it correctly, you will pay someone serious money, like $4-500.00 to tune the system remotely or locally, depending on what's available.
My advice is go spend some serious time out on YouTube, check out a bunch of "how-to" vids on tuning with DSP.
This guide from Audio Frog is a great resource to give you an idea of what tuning with DSP entails:
https://testgear.audiofrog.com/wp-c...Process-and-Some-Notes-About-Why-it-Works.pdf
If you have the money, there are some self-tuning DSPs available; one of the best is the C-DSP 8x12 DL:
You can find these used for around $650.00 plus. That unit will get you to about 80-85% of a professional tune, with just a modicum of learning involved.
Still need a calibration MIC. a laptop, and some trial and error to do it right.
So, no point in recomending any one in particular until you know you are committed to investing a little personal time to learn how.
Honestly in my humble opinion
I think you might just need a brighter top end and a bit more oomf in the low end
I would personally start by upgrading your 3.5 left and right dash speakers to a sensitive coaxial that will incorporate a tweeter
Then maybe your 2 front 6x9's
And maybe plan for a subwoofer using an loc
You may also need to consider your vehicles warranty
If you start running amps and power wires, grounds the dealer may frown on that and give you issues with any warrent issues. But I'm not 100% sure about warranty stuff
Thresher61
Thresher61
Keller, Texas
supernov4
