How many wire runs and number of RMS Watts you running?
The chart shows 1 run of 2/0=283A, so 2 runs of 2/0
should be more than suffficient for 300A according to the given current ratings. There will be a slight voltage drop under FLA operating of ~3%.............. depending on the exact type of cable and length of run.
0AWG (50mm^) power cable is rated for 365A..??
or is 1/0 not 0AWG..??
Hey! It's the Brit shit sack! How are ya matey????? //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
The chart shows 1 run of 2/0=283A, so 2 runs of 2/0 should be more than suffficient for 300A according to the given current ratings. There will be a slight voltage drop under FLA operating of ~3%.............. depending on the exact type of cable and length of run.
so you dont use maximum amps for power transmission?
Thanks guys for helping me out. Went with with 1 run of pos and neg from front and back batteries. Drawing 165 amps at 14.4 so I should be good for a while. Might upgrade to another run of each in the future but I doubt it.
Pretty interesting knowing what other run too! Keep it up
3k rms ish with an sq setup //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif see Sig for details
Also dual runs of 1/0 1 power 1 ground and 2 stinger spv35's up front and an spv70 in the rear
10 Runs of 8/0 awg...10 amplifiers 1 million watts each, 50 16v batteries, 18 h.o. alts, 24 ghetto blaster trillion watt 24" subs at .00001 ohms. 1/0 speaker wire.
i wish i could ban your dumb ass right now.
you are the reason why people avoid this forum. your SN fits you well puke head.
Your post has been reported as trolling. I understand you are just making a joke, but we are trying to keep the tech sections more serious. Im not going to give an infraction because I dont think you had malicious intentions, but I am requesting you remember this in the future. Thank you.
3500W RMS-1 run of 1/0 Kicker Hyperflex directly from alternator lead to rear batteries. 1/0 between all batteries. Once installing my Warhorse, 2 runs of 1/0, one from each alternator post to battery bank. Battery bank connected via aluminum rails.
Does anyone else run straight from alternator?
Lets say you ran one pos from alternator and one run from from battery. Who does this?
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
f1mclarenagr
4SKN
f1mclarenagr
Milwaukee
Joe562MMA
Brendon Jenness
    May 8, 2024
    May 8, 2024
