How good are Digital Designs Woofers?
what model is that
The 9100 series is made for SQ, but its pretty pricey. I have owned every series from 512 to 9512 Composite cone and can be made to sound pretty **** good daily. Smaller box with tune around 35hz and a little less port area than recommended and they sound pretty crisp and punchy, although it may never be confused with a SI Mag
I purchased a dd1010 on another forum with a ported enclosure and it should be here this week. I know that was their entry level sub, but I couldn't pass up the deal I managed to get!
i have a 3515e in a large ported enclosure and it definately gets LOUD, and my girl has a 2512 in a small ported enclosure and its clean crisp punchy bass...
still one of the best woofers available
Depending on your needs. I had a 9515 before. Did it get loud? Yes, but musically, I'll take several other drivers over it. Then again my tastes have changed. I tend to like my setups to get low, accurate, have a smooth response, and blend well with the front stage. I'd say it takes the concept of SQ but bumps the loudness up a bit, not to the point where most people, whether or not in car audio, couldn't handle it.
They are nothing particularly special. If you're looking to achieve high-output over a small bandwidth with less-than-stellar distortion performance, they are among the better brands out there.
Oh no you didn't!
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I think I know the dd your talking about....It said it needs a friend so I have to get it a friend if you know what I mean:D
would you guys take a DD 9515 or a juggernaut 15, if you were looking for something that hits really hard, but still has good sound quality, or a 13w7?
If you want earbleeding loud go with dd9515. If you want to be raped by horribly overpriced subs get a W7
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
rasta4life
rasta4life
New Mexico
Wingman0121
