General sub wiring and setting confirmation.
  • 2
philmb
Hi all.
I just want to make sure i understand a couple of things.
I bought a sub, wired it into the back speaker. Seems ok.
I used the fade to move a little more sound to the sub than the front speakers to stop the front speakers clipping if i turned it up.
When i do this i have plenty of low end but it sounds a bit muddy because i lose the highs from the front speakers as i move the sound more towards the back sub. is there a solution to this?
Or.
Can i just get a 1 channel amp for the sub and keep the other speakers as is as they sound fine?
Also do i just attach an RCA cable to the back of my head unit sub connector - plug the other end into the amp and then the sub to the output on the amp?
does it matter that the head unit is connected to the car speakers through a harness but i would connect the sub via the RCA? Or would i need to connect all the speakers through RCA?
Also can you control the sound of the speakers and sub independently? as in turn the low down a little on the car speakers and have the majority of the lows coming from the sub.
Thank you.
time alignment is not the same as volume. Time alignment is usually only needed when you have an amp or multiple amps, and one has a delay. I...
Looks like it's wire it either 4 or 8 ohm 🤔
829
Okay. Thank you so much! I will run individual power / ground wires to each amp. If the front of the car has no dedicated spot for tweeters, what...
865
You will need distribution blocks for the amps I would run 0 gauge to the blocks and 4 gauge to the amps. For the head unit I would us one that...
191
philmb
philmb
perth, Western Australia
Gunk
DEW123
    May 7, 2024
DEW123
    May 7, 2024
