Gain Setting Tutorial
I have a Sony XM-3001SXD Class D amp running at 1 ohm. I dug up an old issue of Auto Sound and Security and it tested as following -
"We adjusted the input voltage to 6 volts (max the amp is rated to handle) then added 5 db overlap to account for the average levels of music. Here's what we measured playing tracks, not test tones -
Rated/Measured
4 Ohms - 300/462.25
2 Ohms - 600/838.86
1 Ohms - 1000/ UNTESTED - FILL IN THE BLANK FOR ME!
83.7% Efficiency"
So I am trying to see what voltage I should shoot at for my 1 ohm set up.
1000 - 31.62
1200 - 34.64
1400 - 37.41
1600 - 40
1800 - 42.42
I always assumed that the amp is pushing about 1200 watts into 1 ohm but the tests suggest the possibility of more power.
I have ran this amp to a 12" HCCA 12D and now and Orion H2 12.2 and personally hate Sony but this amp has treated me well over the years. What do you think?
I have been trying to set my amp correctly for some time now. I have a JBL 300.1 and it is rated for 150 watts at 4 ohms and 300 at 2 ohms. Right now I am running two JL W0 8 ohm single VC speakers wired in series to produce a 4 ohm load. Using the tutorial this means i should set my amp channel to measure 24.5 ACvolts (sqrt of 150*4). I put in a test tone cd at -6db at 50hz for about a 2:1 ratio. turned the volume up to 26 out of 32 subwoofer level at 0 bass at 0 etc etc. I then proceeded to check the voltage and it was around 22 volts with the gain all the way up to 250mV. I can't ever get the voltage to reach anywhere near 24.5 volts. Am i doing something wrong?? I followed all the directions... im pretty sure my preouts are 4.5v so that would generally mean to barely turn the gain up since the the highest volts are 4 on my amp. Anyways im lost!! I can set it well by ear but i want it to be perfect...
i have a PPI PCX2200(2x200@4ohms) powering a single JL 12w6v2 set in series(8ohm) and bridged. is it (400*8)sqrt? i come up with 56.56v that way. or (400*4)sqrt? 40v that way.
Thanks for any help!
sqrt(400*8) = 56.56V
well i set the amp with my dmm according to the 56.56v setting and it sounds pathetically wimpy. my gain winds up being set at about 1/4. if i turn my comps amp down to match the the sub the whole system sounds like its powered off a headunit. back the way it was. thanks anyway squeak! :)
Thanks to this forum and this thread i will never let someone install anything else for me ever again, I just went through this for a couple hours due to the fact that it was my first time ever and that all the digital shit on the amp complicated it a little, When i checked the volts how the shop had it they were 72.x i believe but they are suppose to be at 44.72 so now that i have them at the correct settings they sound incredible, the only problem i have now is that my components(stock) and my 6x9's(stock) are trying to reproduce some low notes and i cant get them to stop i have the pioneer 860mp headunit does anyone have any suggestions?
you can put 'caps' (capacitors)? on your stock speakers to stop them playing to low. dont know which (value capacitors)ones tho,im sure someone here does.
I have a Profile AP1200 powering 2 RF punch stage 1 subs, one sub connected to each channel @ 200 watts rms(4 ohms). However, the subs RMS is rated at 150 watts. How would I go about making the formula for this? Would it be sqrt(200*4) ; sqrt(400*4) ; sqrt(150*4) ; or sqrt(300*4)
Thanks
sqrt (150*4) = 24.5 volts AC
^^thats per channel on the amp
I have the same exact subs just be careful not to push them they will blow fairly easy
i blew one, the other one is still go tho has about a week and da half play on it... if your interested i can get it out to you just PM me
First of all I want to thank everyone who has contributed to this thread, amazing help.
My question is, I understand how to do all these calculations, but what about setting the voltage to the sub's power rating rather than the amps? Specifically, a (slightly) underpowered sub.
Numbers to make things clearer:
Amp does 280watts RMS at 2 ohms, so I'm looking for 23.6643 volts
However, sub is rated at 300 watts RMS (presents a 2 ohm load of course), so when calculating for the sub's power rating, I get 24.4949 volts.
So what are the consequences of setting the amp to this higher gain level, I mean this can't magically make the amp produce 300 RMS watts when it's only rated at 280, right? So does this automatically introduce distortion/clipping?
Thanks in advance.
and I have that amp and it can blow subs with higher RMS than their output if not set correctly on gains //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i need to set my gains on my amp today and i dont get this formula. how does 100*4= 20? thats not my formula anyways though. i have a JL 300/4 4 channel amp and MBQ 4ohm comps. so thats 75wrms @ 4ohms per channel. My deck is a Pioneer deh-550MP (2V pre-outs i believe)what V should i set mine to? TIA
SirClay
President
SirClay
Texas
Tek18
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
