Gain Setting Tutorial
ok guys i need some help I have a Hifonics 1500D @ 1 ohm and a JBL GTO75.4II @ 4 ohm what voltage I'm looking for at each amp?
What wattage should you be expecting?
I'm sorry I"m so stupid i forgot to mention the watts.well the hifonics is rated at 1500 watts x 1 @ 1ohm but I heard it's over rated so I don't really know the real wattage it will be putting out.the JBL is rated 104 watts x 4 @ 4ohm
thanks in advance
Hi, I have two Rockford p210d4 4 ohm subs hooked up bridged to a rockford p5002 amp. I tried this method, and my subs were crackling and making bad noises like zapping/ electrical sorta after I increased the gains until 44.7 v. The subs and amp are new, and before I had the gain on 0. This was also at a much lower volume than what I tested them at. I have an Eclipse cd4000 hu, and the volume was on 55 when I did the voltmeter gain setting, after when I hooked back up the subs, they were crackling on 45. I turned the gain back down until they sounded OK, which was from about 2/3 when I tested it back to about 1/3. I have the lp on 80, and everything on 0 except sub volume is the highest it can go. Bass boost is 1/4 or less. The subs are so quiet, you can barely hear them. Is that normal for these subs? Can someone help me out? This is the first time I installed an amplifier before, but I think I did everything OK. Sorry this is so long. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Thanks for any help you can offer
Non-fader is like sub volume right? If I turn that to 0, will I be able to set the gain higher? Would I turn the gain up to where it was when I checked it with the voltmeter? Thanks for your help
I have a Lanzar 286 and I have it wired 4 ohms ...... whats the number im looking for? I dont understand the **** JL audio thing thing..
yah im kind of ignorant cut some slack....
and help plz ftw.
Keep it to 0 while setting your gain, i listen to rap mainly so when i put in a rock/soft rock cd from time to time i turn it down to -2 or -3, however most of the time it stays at 0. And yes it the 'sub volume' or should be at least.
SirClay
President
SirClay
Texas
Tek18
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
