Gain Setting Tutorial
Set your EQ to what you normally have it set to when you set the gains. You really should not ever use the Bass Boost.Everything else //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
thanks for the qucik and helpful response.
and as for the crossovers, i dont think i can turn them off? or can i...but if i cant, do i leave them where ill be using them at after everything is set? or place the x-over at the highest it can go?
I finally bought a DMM today and want to properly set my gains. For mids im using 200 watts into 4 ohms. so sqrt(200x4)=28.28 Now for subs im using 400 watts (four channel amp bridged into 2) into a dual 4 ohm load (or two ohm final load). So it would be sqrt(400x2)=28.28.. Im confused as to why both would be at the same voltage. Both amps are PG xenon 200.4's and the subs are L7's.
Should both voltages be the same or am i missing something?
IF YOU'RE REALLY CAUTIOUS OF YOUR EQUIPMENT, THEN USE THE 0dB METHOD.
If you want the MOST out of your equipment, then use the -10dB method.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ya but what i'm asking is am i going to need an o-scope for the -10db method?
What they have that the average n00b lacks:
1) An ear for stress/distortion
2) Experience
3) Proper testing equipment
You tell the average n00b to set his gains using a -10 dB tone and I guarantee you'll see at least some of them blowing shit ...
Many rap songs have bass in the -6 dB area ... You're talking hard clipping (full square wave) when listening at full volume if you used a -10 dB tone ...
So would i be safe goin with a -6 tone? And do you have a -6 45 hz tone i can download? Or is the new tutorial going to be up soon?
SirClay
President
SirClay
Texas
Tek18
