Can i get some help on my system options
truckcap22
ky
i was considering getting a ap3000 for a 18" btl and i noticed that its a it would wire to like 1.4 ohms, and i've read that the ap's dont like to be under 2 ohms period. So would this be alright to run or not? the sub is a dual 1 btl, but the coils are at .7 straight out of fi correct?
also 5-10 cu ft is recommended for this sub, what size do most go with and at what frequency?
With box rise you'll probably be closer to 2 ohm...but who knows, it's hard to calculate box rise in advance (if possible at all?)
As far as the box is concerned, FI should have an "Optimal" enclosure recommendation too
You could do the 8" as a front sub on its own amp and use it to bridge/enhance the gap between your 12" in the rear to the midranges
789
Buddy of mine somehow managed to get small MDF boxes set into the rear doors on his previous truck, think it was an F-150. I can't remember...
Sorry, didn’t watch the video the first time for some reason. Supper helpful video. I will try that. I guess the RMS rating is oversimplified...
Have you talked to him about the electrical? I really want to get deep on this, but lets see how this goes. When you add that amp, you add...
967
truckcap22
truckcap22
ky
DammitJames
    May 24, 2024
    May 23, 2024
