C1500martin 90 RCSB build
Oh, no. Those Tantric subs can handle at least 6000W each. If they don't Murphy will be sure to take care of you on a warranty.
well i dealt with jim not murphy and if they do go bad well ill be sure to send them to psi or somewhere else not tantric unless all these issues are resolved.
I'm sure they could take 4k though many people have given them that with no issues
Thoroughly enjoyed cutting that cab open. Man that was a fun build/install. Gotta meter that bish brotha. I'm looking old these days lol.
Everyone here been getting there boxes made from the dude in sons of anarchy hahaha..
Atleast you keep that califas pride..
Sent from my draconis using Tapatalk
well i dealt with jim not murphy and if they do go bad well ill be sure to send them to psi or somewhere else not tantric unless all these issues are resolved.I'm sure they could take 4k though many people have given them that with no issues
That was a knee-slapper!
Did I say 6000W, I meant 8000W. I saw a guy running a pair of these on a pair of Crossfire 8Ks once so have no fear, OP. They can probably take 10,000W each as long as it's "clean" power and you have a strong electrical system.
There is no limit to the amount of clean power you can send a sub //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Put that towels in your window and do towel trick not your port.
You can see the shirt in the vid cscstang posted, the problem is i lose ALOT of pressure die to my back window it opens up and when i bumped with it closed the glass looked like it was going to break, ima have to find out how much it is to replace it to the sealed windows although its only going to make my truck hotter
16
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
928
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
995
C1500martin
C1500martin
Cali
CSCStang
    May 24, 2024
    May 23, 2024
