C1500martin 90 RCSB build
It has to be clean though... and you need a good electrical system.
Yeah, then you're fine
You can see the shirt in the vid cscstang posted, the problem is i lose ALOT of pressure die to my back window it opens up and when i bumped with it closed the glass looked like it was going to break, ima have to find out how much it is to replace it to the sealed windows although its only going to make my truck hotter
My back window is the same way. Use plexi //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you want it fully sealed then glue the glass using window adhesive or for full on seal get a piece of metal strip and keep pressure on it while welding it in place on the edge of the window.
That way you can use a plasma cutter to remove it later on.
Sent from my draconis using Tapatalk
Well hit my first comp today, took home 2nd place but kinda disapointed, did no wall clamp 4k
146.3@37hz window down in the kick
Subs are only getting about 800 a piece though... Time for another amp to get to 150!
It's called rise. He's prly wire to 1ohm and rising to 5ohm. People would really be surprised at how much power their amp is making if they really clamped it. Lol the clamp meter and the term lab crush dreams lol
I've never heard of rise that bad I've seen 1-2 ohm jumps but not 4ohm but I am newish to the audio game
Sent from my Z812 using Tapatalk
Rise verys from install to install but typical rule is expect x3 rise... So if u wire to 1ohm you prly see power around the 3-4ohm rating
I get more power out of my taramps hd3000. Clamped 2kw..
Shit definitely crushed mine haha
C1500martin
C1500martin
Cali
CSCStang
