Big 3 Help
  • 5
poisoned10
Richmond
I am in the process of upgrading my big 3 and I think I have everything done and just need to put it back together.
Before I do, I wanted to make sure that I have a proper ground to the engine. In the picture is where I have it right now and I think that is the factory ground, but I'm not 100% sure.
So if someone can let me know if this is a proper ground or not I would greatly appreciate it.
Yep, looks good.
I hate seeing red ground wires, you are asking for trouble. If anything, wrap the entire length with black electrical tape so no red is showing. Red is +12V, someone may land that on the positive terminal and explode the battery.
Yep, looks good.
Yep, looks good.
Thanks for confirming!
The audio store I went to gave me the wire and the tards gave me 3 red sleeves and 3 black sleeves. I just put the red one there because I know where that wire is coming from. The other end that goes to the battery has a black sleeve though.
Sleeves alone are not sufficient in my book. Sleeves can be removed. You may know but a mechanic who works on your car may not. I have seen many problems from this, especially at the amp.
I used black wire with the little red and black covers on the end. But mechanics don't work on my car unless it is something beyond my ability. That would be something involving pulling the engine and I'll pull my big 3 if something like that comes along.
Just my preference. I follow industry standard wire colors so any competent installer could follow my work and know exactly what I was doing.
Usually, when we need someone else to work on our cars, it is an emergency.
Your gain should be fine where it is. You could put it on a meter just so you feel better about it though.
Ok, thanks!
I appreciate everyone's quick response.
And by the way, all the wire I ran is orange, not red. Bad lighting I guess made it look red.
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
poisoned10
poisoned10
Richmond
poisoned10
    May 18, 2024
    May 16, 2024
