BC3500 in protect....
That board looks to be in really good shape I think im going to stick with the reason is because it had a short some where along the protect circuit or something that has to do with it.
Its under warranty so im sendin her back
hope they cover it . heard horror stories of the cheaper brands aq crescendo etc. backing out on warranties //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif altho they make solid stuff they dont back their warranties much hope it works out let me know
I dont see why they wouldnt. Theres nothing wrong from just looking at it. Something must have just shorted out.
not saying it to damaged just aq and crescendo have been rumored to say "user error" and charge you for repair . Sundown and dc for example cost more but your paying for a warranty and they will cover stuff period just saying heard a lot of stories from reliable sources and people its happened to
Was it used before you got it?
If the amp was mounted to a box it can be damaged. I bought an amp that was mounted to a box and it just went into protect. Vibrations loosened something up.
I understand but this is a short out i guess tho.. But i guess we will see. Like i said the amp inside and out is spotless. Only little scratch is on the mounting feet of it.
idk how the other guy had it. But IF i mount to the box i have a inch & half of rubber and shok proof materieal the box and amp.
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
Not sure If I can Help you fix the issue without being present.. But the first thing i would do is remove all RCAs and All speaker wires from the...
maybe bad amps. I would purchase a decent amp off of Amazon. They usually arrive in 2 days if you have "Prime." If the problem persists, you can...
You don't understand understand brazilian amps and how finicky they can be about voltage...everything you just said nonsense
13
bgowdy
Heroes are remembered, but legends never die
bgowdy
Campbellsville, Ky
bgowdy
    May 24, 2024
    May 23, 2024
