I doubt you will have that much trouble pulling a hair trickYeah, that's what I was thinking.
If it doesn't do what I want, I'll just keep adding port length until the hair gets //content.invisioncic.com/y282845/emoticons/silly.gif.3549b64aaa5b6729eb8e865319a3234f.gif
It started raining, so I figured I'd take a quick pic of my progress and update my build logs. One side is almost done //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The white caulk in the background was there from my last build. I'm salvaging the floor and back panels. I'll scrape it off before I resin the corner and side wall
Those are 2x4's turned sideways. The side is 3" of solid wood. Glued and screwed, plus will be covered with resin inside and out. Very sturdy to say the least
Thanks, it was just the way you worded it. I couldn't tell if you were serious
Hispls would disagree that I need more power //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
So are screwing the 2x4's together and any glue ? No criticism from it's a serious question. Anyway, the concept seems legit , let us know how it turns out.
Yeah, true. I do like the idea of having a short port so you can look in and see the motors easily thoughI like low tuned big box. My truck is tuned to 30hz and my next wall will be tuned to 25hz or lower... You don't loose output tuned low if you do it right, prime example is the Hhr, it's tuned to 25hz and does 155db at 23hz and 160.5db at 35hz. ur pretty close to Michigan you should come hear the Hhr one of these days.
Thanks, lol. Finally a positive commentThats a lot of work, very good.
At that stage it looked like your truck was having a sauna installed!
Subscribed, I like your project, cant wait to see it getting closer to being finished.
Ok, there it's easy to detect sarcasmOh no, I was just joking with you earlier. You could actually gain as much as 8dB from doubling power. You just won't know until you try it.
Of course, glued and screwed. Then going to resin over everythingSo are you screwing the 2x4's together and are you using any glue ? No criticism from it's a serious question. Anyway, the concept seems legit , let us know how it turns out.
ThanksNever but I assumed and cool beans bro, wish you the best in you build .
Dang u rebelYeah, true. I do like the idea of having a short port so you can look in and see the motors easily though
I drove half way to Tennesse and back on Friday without my mom knowing, but Michigan is much further, lol. I'd definitely have to have her approval
Thanks
