Babykinns 10+ year member
i know a lot of you will probably laff at me but i accidently hooked the ground and power wire up backwards on my scosche efx 1000watt 4 channel amp bcuz i wasnt payin attention when i put the fuse in the power cord it sparked so i checked the wires and realized what i did then took the fuse out and hooked it up right then my subs hit once and the amp went into protect mode and now thats all it does any advice or info of whats wrong and whether my amp is burned up or not would be very greatly appreciated
its powered with a 4 gauge power and 8 gauge ground
these are the specs for the amp
65 Watts x 2 Ch (Front) & 110 Watts x 2 Ch
(Rear) RMS Output Power (@ 0.09% THD
from 20 Hz ~20 kHz into 4 Ohms)
85 Watts x 2 Ch (Front) & 140 Watts x 2 Ch
(Rear) RMS Output Power (2 Ohm)
? 170 Watts Bridged (Front) & 280 Watts
Bridged (Rear) RMS Output Power (4 Ohm)
1250 Watts Total Maximum Output Power
Low Impendence 2 Ohm Load Capability
(Stereo only)
Bridgeable - 2/3/4 Channels
Multi-Mode Capability
Adjustable High Pass/ Low Pass Electronic
Crossover (40Hz ~400Hz)
Adjustable Bass Boost (0~ + 12dB @ 45Hz)
Line Level & Speaker Level Inputs
Soft Start Turn-on/off
Over Heating & Short Circuit Protection
Adjustable Gain Control (200mv ~ 6 Volts)
MOSFET Power Switching Transistors
Frequency Response............... 20 Hz~20 kHz +- 0.5 dB
Signal to Noise Ratio .......................................... Greater than 98dB
THD + Noise ....................................................... Less then .09% from 20 Hz~20 kHz into 4 ohms
Bass Boost ..........................................................0~12 dB @ 45Hz
Electronic Crossover ........................................... 12 dB/oct. 40Hz~400Hz
Speaker Load Impedance ..................................2~4 ohms in stereo mode
Power Input Voltage ............................................ 14.4 VDC (10.8~15.6 VDC allowable)
SA4004 Dimensions ............................................ 2-7/16” x 10” x 13”
SA6004 Dimensions ............................................ 2-7/16” x 10” x 15-9/16”
(Stereo only)
