accidently hooked ground and power up backwards
Babykinns
i know a lot of you will probably laff at me but i accidently hooked the ground and power wire up backwards on my scosche efx 1000watt 4 channel amp bcuz i wasnt payin attention when i put the fuse in the power cord it sparked so i checked the wires and realized what i did then took the fuse out and hooked it up right then my subs hit once and the amp went into protect mode and now thats all it does any advice or info of whats wrong and whether my amp is burned up or not would be very greatly appreciated
its powered with a 4 gauge power and 8 gauge ground
these are the specs for the amp
65 Watts x 2 Ch (Front) & 110 Watts x 2 Ch
(Rear) RMS Output Power (@ 0.09% THD
from 20 Hz ~20 kHz into 4 Ohms)
85 Watts x 2 Ch (Front) & 140 Watts x 2 Ch
(Rear) RMS Output Power (2 Ohm)
? 170 Watts Bridged (Front) & 280 Watts
Bridged (Rear) RMS Output Power (4 Ohm)
1250 Watts Total Maximum Output Power
Low Impendence 2 Ohm Load Capability
(Stereo only)
Bridgeable - 2/3/4 Channels
Multi-Mode Capability
Adjustable High Pass/ Low Pass Electronic
Crossover (40Hz ~400Hz)
Adjustable Bass Boost (0~ + 12dB @ 45Hz)
Line Level & Speaker Level Inputs
Soft Start Turn-on/off
Over Heating & Short Circuit Protection
Adjustable Gain Control (200mv ~ 6 Volts)
MOSFET Power Switching Transistors
Frequency Response............... 20 Hz~20 kHz +- 0.5 dB
Signal to Noise Ratio .......................................... Greater than 98dB
THD + Noise ....................................................... Less then .09% from 20 Hz~20 kHz into 4 ohms
Bass Boost ..........................................................0~12 dB @ 45Hz
Electronic Crossover ........................................... 12 dB/oct. 40Hz~400Hz
Speaker Load Impedance ..................................2~4 ohms in stereo mode
Power Input Voltage ............................................ 14.4 VDC (10.8~15.6 VDC allowable)
SA4004 Dimensions ............................................ 2-7/16” x 10” x 13”
SA6004 Dimensions ............................................ 2-7/16” x 10” x 15-9/16”
Some of the better amps have protection against that, but some of the lesser ones don't. You're going to want to open that up and look for any burn marks or something that looks awry. You're sure nothing else is wired wrong?
was no smoke at all no burnt smell havent opened it up yet tho has a 80 amp fuse between the power wire and amp and a 35 amp+ a 25 amp in the amp itself
Oh, those small fuses definitely should have blown first. What size wire?
4 gauge power 8 gauge ground
You're going to want the same size power and ground wires.
they may have been under stress when you wired them wrong and when powered back up just blew
^^^This. Go back and re-check everything. If you find no fuses blown, and you're sure the wiring is done right, open that amp up.
I'm guessing that's what it is. There's not a lot of room back there.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
Yeah I saw a lot of that when doing those installs as we also did surround sound system wiring as well. I always ended up being the doing it as...
Babykinns
Babykinns
Nelsonville, OH
Babykinns
    Apr 28, 2024
    Apr 28, 2024
